Carrier comfort zone II (Zonecc (2,4,8))
Hey. Just bought my 1st house in May. My dad came to live with me. He has dementia. Feel sorry for me. haha
so, the thermostat display is dead. i don't know what is going on. the previous owner was an hvac wiz. left the manuals, but they don't say anything about this problem
    Master:
    Sergeant:
  • 482 Answers
Replace the thermostat
Posted on Nov 28, 2007
  • Farren Wadley
    Farren Wadley Nov 28, 2007
    check for a breaker around the house, and see if any of the show red, fip it.
SOURCE:
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
I have a Carrier Comfort Zone II with 2 controlled zones. The floor with just the sensor controls perfectly. I set that zone at 75 and it stays at 75. The other zone has the actual thermostat. If I se
Sounds to me like a bad damper or a bad zone panel. Turn tstat off and call for cooling on zone 2. Then see if your still getting cool air to zone 1.( where the main tstat is)
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 15, 2017 | Heating & Cooling
Tracfone customer service
The tracfones have different sim for different carriers, so your dads may have a different sim in his and works better than the sim in yours. You can try calling tracfone and get a new sim that will work better in your area.
Mar 18, 2014 | Computers & Internet
My carrier comfort zone II thermostat is flashing E1. What does this mean and why am I having trouble setting my temps?
I suspect that if you change the battery in the thermostat. All will be right again.
Thanks for choosing FixYa.
Aug 27, 2011 | Carrier Heating & Cooling
Our Carrier Comfort Zone II thermostat, which has 2 zone readouts, currently shows a temperature of 00, as in zero zero, on one zone. That is the main zone for our home. Zone 2, for spare bedrooms, etc....
This .pdf file may be of help to you:
www.brivis.com.au/.../Carrier%20Comfort%20Zone%20II%20Owner's%20Guide.pdf
Perhaps you could get some help from Carrier Support here:
http://www.residential.carrier.com/support/index.shtml
I noticed they have an option of talking to an engineer, and perhaps they could explain how to reset or set the unit.
Hope this helps.
Sep 25, 2010 | Heating & Cooling
We have the same problem, was hit with lightning and came up E1
You didn't get a Carrier tech. Carrier technicians only work on commercial equipment. Residential applicaitions, installation and service of Carrier residential units are done by dealers. They are not carrier owned but get buy the product at discount get training and get to show our logo. You can't fix the boards, they have to be replaced. It sounds like you have a Gen II VVT system. You can get the part via Totaline stores or a distributor. You will need to know how to readdress the other controllers to operate correctly. Use WWW.Carrier.com.
Aug 03, 2009 | Carrier 38CKC060 Air Conditioner
Carrier Comfort zone 2 is flashing e1 after a storm/power outage
HEY THERE, DID YOU TRY POER CYCLING THE UNIT? TURN IT OFF AT THE BREAKER THEN BACK ON
SETH
Jun 27, 2009 | Carrier 38CKC060 Air Conditioner
I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Jun 24, 2009 | Carrier 38CKC060 Air Conditioner
Thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Feb 18, 2009 | Carrier 38CKC060 Air Conditioner
Carrier Comfort Zone ii - trying to find user manual
Your description leads me to believe you have 2 thermostats. How long have you lived in the house? Did it work for you lately? Sometimes its just the door switch. If you have to remove it to change the filter or had it off for another reason hold the switch in by hand and try it. then check the door for correct channeling in the grooves provided and see if this is it.
Jan 19, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
800 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
