Question about Trendware TEW-432BRP 54Mbps Wireless Firewall Router
Cannot access the network
I cannot access the network while using the router. the system light is off(it used to be working normaly)i made a reset but didn't work
    Master:
    Sergeant:
  • 482 Answers
You have to call you phone company, they can run a test on it, they can reset the code in it. all the lights have to be on for it to work.
Posted on Nov 28, 2007
SOURCE:
I have a new note book that I would like to add to my wireless belkin.15e and I do not remember the password how do I access it
Resetting the Router
Reset button - Red
The "Reset" button is used in rare cases when the Router
may function improperly. Resetting the Router will restore the
Router's normal operation while maintaining the programmed
settings. You can also restore the factory default settings by
using the "Reset" button. Use the restore option in instances
where you may have forgotten your custom password.
Push and release the "Reset" button. The lights on the Router will
momentarily flash. The "Router" light will begin to blink. When
the "Router" light becomes solid again, the reset is complete.
Restoring Your Router to factory Defaults
Press and hold the "Reset" button for at least 10 seconds,
and then release it. The lights on the Router will momentarily
flash. The "Router" light will begin to blink. When the "Router"
light becomes solid again, the restore is complete.
page 22 of the router manual
http://www.belkin.com/networking/manual/MAN_F9K1001_8820-00773_RevA01_N150_Router.pdf
Mar 19, 2014 | Computers & Internet
My linksys router doesnt have a default gateway and the reset buttton on the router doesnt work either
When you look between the Ethernet port and Power button, there should be a reset button there you should hold for 5 seconds. Of course if you do that, If you changed Network name and key that will be reset to the default settings, Also is wireless network showing when you pull up the Networks? You can leave user name blank, but default password is admin. Also email me with more info I will be glad to help
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&app=vw&vw=1&login=1&json=1&docid=1e97db4854604b0fb5cc8c0d74491e35_19584.xml
Dec 26, 2011 | Linksys WRT54G3G Wireless Router...
Need to find out password or how to reset a new password
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
dont forget to vote hope this helps
Feb 05, 2011 | NetGear WGR614 Wireless Router
My router is 2 years old and yesterday, i started to get the message saying i am not connected to the network. Does that mean the router is no longer working ?
What is giving you thisw message? If it is on a laptop, accessing router wirelessly, then (on the laptop) go into Network Settings and verify that your computer is set up to use a Private network, as Public networks may not let you see other computers on the network. If it is set to Private, then your router may have stopped working. Try resetting the router by sticking a paper clip into the Reset hole, which resets the router to Factory Settings. Go ahead and connect to the router with a CAT-5 cable and use IE to go go to http://192.168.1.1 and complete setting (simplified) as follows:
In Wireless Section, Choose your SSID (Network Name), set security in the section below that by choosing security method and passcode. This passcode MUST be used by all users to access thev wireless signal. Let me know ( [email protected] ) if this does not help.
Dec 17, 2009 | NetGear RP614 Router
Need to reset logon password
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Nov 22, 2009 | Gateway Wireless-B Router (wbr-100)
Cannot access DI-624+ router through http://192.168.0.1/
1. click on start
2. run
3. type cmd
Oct 02, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Using a DI-614+ router with a Charter cable modem, I can access the internet just fine, but the speed was just slow. I went to fiddling around with the settings and no longer can access the router with...
1. click on start
2. run
3. type cmd
Sep 29, 2009 | Computers & Internet
Cannot access d-link router
Are you trying to setup router?
this is very easy.
Click Here for step by step solution.
Sep 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I keep losing the internet signal and going offline. LAN indicates pending??? How do I perform a system reset with Linux??
Power cycle the system by shutting it down and switching it on after at least thirty seconds. Check network settings to verify the IP address and other related information. Determine if the network card is working adequately. Identify the malfunctioning adapter by disabling the cards one by one. Move one of the portable hosts--such as a laptop--closer to the router. If it works better, interference or low signal strength is the reason for poor Internet access. Inadequate signal performance can be caused by several factors including cordless devices working within the frequency range (2.4 GHz) of a wireless network, shiny surfaces and too much distance between hosts and access points. Resolve this issue by using a wireless repeater?a device that amplifies wireless signal so it reaches distant areas within the premises. Minimize signal interference by maintaining a distance of at least one meter between cordless devices and the router. Alternatively, buy gadgets that function at frequencies other than 2.4 GHz. Try changing the WiFi channel for better results. Check the functioning of wireless router and access points. Adjust the router antenna to get an optimum signal. Most wireless routers come with omni-directional antennae to send signals in all directions, a situation appropriate for a square-shaped network. If hosts are arranged in a linear fashion, use an antenna that sends signals only in one direction. Some portable routers have internal antenna, giving more freedom to users who are on the go. Use an external antenna with such routers. The market now offers antennae with varying strengths, implying some are more powerful than others. See if using a more powerful antenna fixes the problem. Aside from increasing the range of transmitted signals, the reception capacity of hosts can also be enhanced. External WiFi-enabled antennae attached to laptops are now available for this purpose. Change the location of the router and access point. They should ideally be placed centrally between all computers. As the signal bounces off smooth and shiny surfaces, routers and access points should be placed away from windows, doors, mirrors and other metallic surfaces. Examine signal performance by using the monitoring utility that typically comes with the access point. Check that the devices show correct lights. Device lights are an indicator of accurate connections. Different lighting patterns indicate different things. For example, some network cards show green light on successfully establishing a connection. Similarly, the router's wireless LAN (WLAN) light is turned on at all times, even if no device is connected to it. Further, this light blinks when a host communicates with another host. Unexpected lighting indicates a problem. Go through user manuals to get familiar with this feature and make sure the devices show desired lighting behavior. Use wireless Internet utilities to check the SSIDs and channels neighboring wireless networks are using. Change your network's SSID and/or channel if they are the same as that of other networks in the vicinity. See if correct drivers have been installed. Check configuration settings for encryption keys.
Sep 24, 2009 | ASUS Eee PC 2G Surf Notebook
Trendware TEW-432BRP 54Mbps Wireless Firewall Router Logo
151 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Duncan Mutch
Ekse
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
