Question about HP Compaq Presario V2000 Notebook
Pc to TV, NO color
I have hooked up my V2000 laptop to a TV/VCR thru the S port to an RCA port on the TV/VCR. I get good picture and sound but it is in black and white. Tried the same thing on another newer TV with the same result. Have been on 2 chats with HP techs but they weren't able to figure it out either. Any ideas?
  • Mac8tac Nov 28, 2007
    I have been to the advanced to set up the display but am not sure how to adjust the video card to get the color in the TV display. There are a lot of options in color management, should I keep trying different settings there? Any suggestions would be appreciated.
  • 51 Answers
I have hooked up my laptop to the TV using the S port. I haven't seen the best results yet.
Have you checked the display driver settings? Control Panel -> Display -> Settings -> Advanced.
Here you have a bit more options on tweaking the video card.
Posted on Nov 28, 2007
SOURCE:
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
Connect a Wii to VCR
Hello
Take the Wii's audio/video cable and the power cord and hook them up in the back of the Wii.
Take the Wii's audio/video cable and plug it into the 'audio-in and video-in sockets on your VCR.Make sure you match the cable colors with the input colors.i.e white goes with white,yellow with yellow and red with red.
Take the RCA cable which looks like the picture below,
and plug one end of this audio/video cable into the 'audio out' and 'video out' ports on the VCR.Make sure the cable and ports colors match.
Now take the other end of the RCA cable and plug into the 'audio in' and 'video in' ports on your TV.Again make sure you match the color connections.
Hope it helps.
Ken
Jan 22, 2012 | Nintendo Wii Console
I can get picture with hdmi connected but no sound. Do i have to connect the optical digital audio cable from PC to TV to get sound? Actually the video and sound go to stereo receiver first, video passes...
If your video card supports audio over hdmi in that case you need to find the s/pdif port on you motherboard and the port on your video card (usually right next to and sli or xfire bridge) then you can send the sound thru the hdmi. if not you will have to connect your optical audio cable or a 3.5mm audio out to rca left and right out to your receiver for audio. what video card and mother board are you using? if you know this i can tell you exactly where the ports are for the spdif cable to video card and mobo.
Mar 15, 2011 | Computers & Internet
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
Problems hooking a PS1 to a Panasonic 42" tv
your vcr has the yellow, white, and red (RCA) ports but your playstation will not. you have to buy an addapter cable to go from playstation to vcr. http://www.gocybershop.ca/customer/product.php?productid=133&cat=163
btw on your vcr the RCA inputs are not colored (if you have the one in the picture. but just as a guide, yellow=video, red=right(R), white=left(L).
Aug 06, 2009 | Panasonic PV-V4540 VHS VCR
Sound thru tv
You will need a cord that plus into the headphone jack or speaker out jack on the computer and has rca end to plug into the audio input on the TV.It will look like the one pictured.Please rate this solution.
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Different sound to picture
When connecting VCR to TV. Verify all connections. First if the connection is with coaxial cable make sure you signal from outside is screwed to the cable input on VCR. Then the VCR/TV output has the cable running to TV input. If hooking up with RCA cables , which is the yellow, red, and white cables. Hook one side up to VCR output. Yellow for Video, while red/white to audio output matching the colors. The same is done to the Television input. yellow for video, red/white for audio. Do a test recording. Use a blank tape, not one already recorded on. Record about 5 minutes Stop recording , rewind and playback. You should see the difference.
Oct 13, 2008 | Televison & Video
I need help with my tv and dvd/vcr combo
Hmmmm...I dont understand exactly what you are saying, but it sounds like your TV doesnt have RCA ports and you want to hook up a newer DVD player that uses RCA ports. If you have only a cable port (silver threads with a hole sticking out of back) on TV and RCA ports on DVD player, you have to buy a converter. You can get one at Wal-Mart for 20-30 dollars. Or you can just update your TV which it sounds like you badly need to do! :)
Dec 24, 2007 | Sanyo DVW-7200 DVD/VCR
Rca 36" tv
are you on outside antenna or cable? does vcr or dvd do the same?
sounds like tunner in dvd or vcr works.
Dec 03, 2007 | RCA F36650 36" TV
RCA 27"
I suggest you check your Direct TV box. It may be off frequency. Stargazer
Jan 05, 2007 | RCA 27F650T 27" TV
HP Compaq Presario V2000 Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
