Question about Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera
Memory Card Error
I recently purchased a 4GB SD memory card and now camera reads memory card error. Can it handle this size memory card?
  • Gigiswise Dec 18, 2007
    I recently purchased a 4GB SD memory card and now camera reads memory card error. Can it handle this size memory card? Also, is it possible to retrieve my pictures?
  • Anonymous Mar 14, 2014
    Hi i have a memory card read error problem with my camera. so when i opened my K-m pentax camera and found that the smd transistor behind the card reader indicating light is blackened.
    i need some help whether repalcing the damaged transistor will rectify the memory card read error
  • 36 Answers
Use USB card reader&writer to retrieve the pictures directly from the card.
Posted on Dec 28, 2007
Can I use a 4gb sd hc memory card in a canon powershot s2 1s? the screen says there's a memory card error
The Max. Memory Size of ur camera is : 2048Mb/2GB.........That is reason for which it says that there is a memory card error.
Feb 17, 2011 | Canon PowerShot S2 IS Digital Camera
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
C190-caot be read with 2 differnd SD 4GB cards. Is
Hi sir
#1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Mar 15, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Memory card error replaced card but still get error message?
Is it the SD memory card? or the Micro HDD(4GB) you're pertaining to. In case of micro hdd not detected or error, micro hdd socket(CF) assembly has a problem most likely, need to be replaced. SD card; check your SD card's capacity, it can handle only up to 2GB or try to format your card elsewhere and re insert it again in your camcorder, if it will prompt you "FORMAT SD CARD?" you're lucky
Feb 25, 2010 | JVC GZ-MC500 Memory Card Camcorder
Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
Feb 16, 2009 | Samsung S830 Digital Camera
Panasonic fz 18
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Aug 25, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
MEMORY CARD ERROR
From what I can see here, the card's size is too large that your camera couldn't support or handle. Maybe your camera is just limited to 1GB or 2GB. Try plugging 2GB card and see if it detects it. I had similar prob where I bought a 4GB card and it does exactly the same thing. I consulted the vendor, he said it only supports up to 2GB thus, it's a product limitation...well I'm stuck there hehe, can't be helped at all..
If you are certain that your camera can handle 4GB card or higher, try to plug the 4GB card into a card reader and see if it detets it. If it does, try to reformat the card and try it again to your camera.
Also, 1 possible thing is that your 4GB card is password protected. Was it plugged in to any other device? If it was, try to plug it back to the same device where it was connected and disable the password.
Onother thing is the brand. Some camera is brand sensitive when it comes to cards. You may need to try different brand as well.
Hope this helps. :-)
Jan 06, 2008 | Canon PowerShot A540 Digital Camera
SD memory card limit?
The A430 works with MMC and SD cards. Your 4GB card is actually an SDHC card and will not work with this camera. You need to use SD cards, which max out at 2GB.
Dec 31, 2007 | Canon PowerShot A430 Digital Camera
Memory Card Error
Sounds like the camera does not support SDHC. Check manual to see if this camera supports high capacity SD cards.
Dec 19, 2007 | Canon PowerShot SD700 IS Digital ELPH /...
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera Logo
425 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
