Question about Nikon COOLPIX P3 Digital Camera
LENS PROBLEM WHEN I TURN MY CAMERA ON,HE LEN'S DONT COME OUT,IT SAY'S LEN'S ERRO,CAN YOU TELL ME WHY IT'S DOING THIS?
  • das_sonu Jun 30, 2008
    when i on the camera ,the shutter opens and then again close back giving a lens error sign on the screen.pls advice me
  • Nikon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
SOURCE:
My Kodak easy-share len is stuck. what do this Len error 20e 1,0,0 means?
There are some steps which can be followed which may resolve this problem which as follows,
1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
3: Just push and pull the lens slightly as it extends automatically.
4: Now when the lens is in the hard surface power on your camera.
5: Try to hit the camera softly beside the lens which might solve the issue.
You can try to format the memory card completely and then reinsert to your camera which might be the issue at times.
Sep 13, 2014 | Kodak Cameras
Canon sx120is fell while taking photos it went off with the lens retracted and it wont turn on
that is definitely the problem with the len,the len is stucked can not change freely.change the len or send to the camera repair center.
http://www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:[email protected]
Oct 12, 2011 | Canon PowerShot SX120 IS Digital Camera
Lens error
change your battteries installl new one
Aug 23, 2009 | Canon IXUS V2 Digital Camera
NIKON LEN /CANNON LEN
Search ebay or a search engine like Google with nikon canon lens adapter as the entry. There are two kinds. One is mechanical (cheaper); the other has some electronics (expensive). Mount the adapter on the lens then mount onto camera. See www.kenrockwell.com/tech/nikcan.htm
Aug 21, 2009 | Canon Cameras
Len won't close , camera won't work
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 17, 2009 | Cameras
Len error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jan 07, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Len
camera lens has problem.
need repair lens
mydc digital camera reapir
Jun 05, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Lens error No. 221,0,0,0
I have Pentex Optio E 30 camera
When i start my camera , i get error message Lens Error : 221,0,0,0
lens got stuck and it is not coming out for zooming
Sep 06, 2007 | Kodak EasyShare C703 Digital Camera
Lens Error
Two posibilities : either the gear box needs attention or the lens itself is impacted . The first problem is not so expensive to sort out by your repair outfit but the impacted lens problem is expensive ( may require replacing lens assy. ). Anyway camera has to go in I am affraid.
Aug 24, 2007 | Kodak EasyShare C643 Digital Camera
Nikon COOLPIX P3 Digital Camera Logo
207 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
