Question about Car Audio & Video
Starting problem I have a 1994 jeep cherokee laredo and had a used computer put in. I had the mechanic look at it and he said it was the computer that was bad, so it was fixed. Now Im having the same problem again. The car starts but does not want to stay on, can you please help me.
  • IntroubleNY Nov 30, 2007
    Thank you, I took my jeep to the mechanic and he changed the fuel pump and I just brought my jeep home and it did the same thing. I'm going to take your suggestion and test my battery. Thank you again.
    Problem Solver:
  • 14 Answers
First of all, what type of a mechanic looked at it and diagnosed it as the "computer"? A certified dealer-type technician, or an independent shop mechanic? I ask this because a vehicle's engine ecu is very frequently mis-diagnosed when it may be something as simple as a loose connector. What exactly happens? You crank, the vehicle starts ok, then runs good for a while then dies, or dies right after starting? Does it run rough after you start it? Without further info, I'd say you may have a bad battery. The engine control unit (ecu or "computer") is very touchy, and what happens many times is that your vehicle may crank ok, but while cranking, the voltage will drop too low, and erase the computer's recent memory ( things like throttle position, crankshaft sensor variation, etc.). So when it does fire, it will not idle properly, or sometimes will not run at all. Chrysler, Dodge, and Jeeps are especially susceptible to this. One thing you can do is if it cranks then starts, rev the engine to keep it running, not mash the pedal, but hold it at about 2000-3000 rpm for 10-30 seconds and after that, gently release the pedal, and let idle. if it runs ok after that, drive it to buy a battery. If this is not the case, you may need some more serious electronic diagnosis. Look over the obvious things like your battery cables to ensure they're tight and no corrosion, also follow those cables to the starter/engine/or exterior fuse panel, and make sure the connections are good. I hope this helps. I would definitely get the battery load tested (they do this at autozone for free), and go from there. Good luck.
Posted on Nov 28, 2007
1994 jeep cherokee will not start when temperture is below 76 degrees?
The starter is located between the firewall and the engine, underneath fuel injection assembly
Jul 23, 2014 | Denso 1994 Jeep Grand Cherokee Laredo 4.0L...
My 1994 jeep grand Cherokee Laredo will not start or stay running.turns over but will not fire,but then sometimes it will.when it does start it runs very rough and will stall if I try to restart it...
If it's been sitting a while it's always a good idea to put some sort of gas treatment in it. Ethanol added to gas nowadays is bad about getting water in it if it sets.
Jun 22, 2017 | 1994 Jeep Grand Cherokee
Fixing a 1994 Jeep Grand Cherokee Laredo's power
I would assume that one hose is for either side. I would get a measurement of the old hose
Apr 11, 2013 | Cars & Trucks
Back up lights on 1994 Grand Cherokee Laredo not working
You have a back up lamp relay in the (power distribution center) by your battery9be6eb73-dcd0-4a56-aac3-d302489dbf38.jpg
Mar 24, 2013 | 1994 Jeep Grand Cherokee
Problems starting a 1994 grand jeep cherokee laredo
Hi. Thanks for your question. For issue related to jeep cherokee laredo you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
Feb 25, 2018 | 1994 Jeep Grand Cherokee
1994 jeep cherokee laredo using lots of oil. Believe it's spewing out when I drive 'cause found lots of oil on wheel covers. Someone said it's probably front seal. Before I take it to...
I dont see how the oil made its way to the wheel covers, but as for the oil loss, it sounds like a broken seal, more than likely your from main or crankshaft seal, that equieres mechanics expertise and tools to replace, no choie but to take it into the shop.
Good luck.
Aug 23, 2011 | 1994 Jeep Grand Cherokee
1994 4.0 Jeep Grand Laredo Tramsmission Leak
I hope they didnt over fill it when they did the seal a few months ago..
Did the mech say what would cause the overflow ??
Maybe call a trani shop & get a 2nd opinion..
Ask them what causes a overflow..
Jul 09, 2009 | 1994 Jeep Grand Cherokee
1994 Grand Cherokee Laredo Blocked Orifice tube
I have a 1994 jeep laredo. When I make a u turn there's a loud sound while making the turn and the car starts skipping until I turn the wheel straight. What causes that?
Jun 13, 2008 | 1994 Jeep Grand Cherokee
Car Audio & Video Logo
132 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
