Question about Logitech LX7 Cordless Optical Mouse
Logitech LX-7 Wireless mouse
I have had nothing but good from this LX-7 and it is great. My left mouse button is sticky now and I have to really click harder to get a response. I suspected it was dirty and tried compressed air to an extent. I want to disassemble this baby and check my micro switches and do a thourough cleaning, but I do not see any case screws. Has anyone every dealt with taking one of these apart? I have checked the inside battery compartment and see no screws. My upper buttons are merely flaps in in the casing with no actual button. I did try a fine screw driver and to lift a flap enough for the air cleaning, but it didn't seem to solve my clickability. Any suggestions would be greatly appreciated.
  • 1 more comment
  • Buzzinator Dec 02, 2007
    Thanks Agas. I got it apart to exam the inside. I checked both micro-switches and they appear to have the same tension in their function. I noticed that the mouse upper cover pads that press down on the micro-switch contact were notched from wear and the micro-switch contacts are worn some. I didn't have epoxy or glue, so I built the pad up with some tiny slivers of metalic tape. Working fine now, I just have to locate some parts from some where to make a permanent repair.
  • Anonymous Oct 27, 2008
    I have the same problem thanx for the help! BTW for the record the LX7 is a superior mouse two double AA's will last a year!!!
  • blitzbusta Apr 09, 2009
    Hey, i also need help due to a 'similar' problem with the same mouse:
    I dropped my mouse from a height of bout, 30cm now the wheel's gone like stuck with the LMB. the RMB is perfectly fine, but if i click the LMB i have to click very hard for it to work. Becuz this mouse has side scroll if i move the mouse wheel to the right it also again gets stuck , ( it kinda fixes the LMB as in it nows clicks perfectly), but now it keeps side srolling and doesn't scoll properly. I've taken it apart thankx to Agas' instructions, but no luck. I don't know what to do after i've taken it apart.
    Also this is practically a new-ish mouse (2-3 months). And its the second time this has happened, i had to throw away my first logitect mouse due to the same problem.
    Plz help me, i don't want to buy a THIRD mouse.
2 screws are located in the battery compartment. They are under that flappy plastic thing that helps you get the Batteries out. The remaining 2 screws are under the "glide pads" in the front of the mouse. Fingernails are helpful ;) Don´t hurt yourself. Try not to get any dirt on the adhesive or you won't be able to stick them back for reassembly.
Anyways.... after opening thats where the Fun really starts... Just spilled some Coffee over mine... still working on how to get all the inner workings out
Posted on Nov 30, 2007
Buzzinator's diagnostic is right on. The microswitch has a hard plastic (as it should) while the pads on the pillars that reach down and actuate the microswitchs are of a softer plastic. For the left button, the notch is all the way across the pads while for the right button, the notch is still growing from one side, but still works.  I don't have epoxy either, nor metal tape (great idea!). So I filled in the notch with superglue! Bad choice, I know, but it's all I have at the moment.
Posted on Dec 22, 2008
  • cclayton6 Dec 22, 2008
    Although I like Buzzinator's solution (and, of course, mine), here is a more extreme solution that requires adjusting the spring tension within the microswitch itself! I don't like it. The notch is clearly the problem.
    http://www.overclockers.com/index.php?op...
    New Friend:
While you're cleaning the insides, you can also make some adjustments that will make your scrolling silent, and allow it to be "free scrolling" so a big flick of the wheel will scroll much further than a little flick.
Remove the scroll wheel's clamp (very front of the circuit board, held on with a single screw). Lift off the entire scroll wheel and the cage it sits in.
Remove the wheel from the cage carefully, then remove the inner portion of the wheel on the left side (the side that doesn't have little radial groove marks). This is the "spring" that is causing tactile and sound feedback for scrolling. Place the "empty" wheel back into the outer cage.
Take the clip you unscrewed from the board (the tiny mouse wheel one) and place it back onto the wheel's cage front. Place the entire combined unit back onto the circuit board, affixing the screw in the clip last. Be sure you didn't lose the tiny spring under the cage that registers wheel down-clicks; it's not affixed with glue, so it can fall. If it did fall, it quickly re-attaches to peg at the back of the cage (not the middle one).
Posted on Jan 07, 2015
If after cleaning the "Glide pads" with alcohol, the button continues sticky, unscrew just a little the screws under the pads.
Posted on Dec 02, 2007
I have a Logitech LX-6 cordless optical mouse. Lately it's been double clicking when I press the left button - not always, but often enough that it's irritating. I'd like to take it apart and clean the...
Quite often there is a label on the bottom and this hides a screw which holds the mouse together. If there is a label on the bottom, try rubbing your finger over it to see if you can feel a hole underneath. Also on the bottom are plastic glide pads which help the mouse to move freely. If there is a large one towards the back then it may also hide a screw. Use a thin blade to lift off the glide pad and hopefully the sticky layer will remain sticky to make it easier to put back.
Feb 25, 2011 | Logitech Cordless Mouse
Trying to install logitech wireless mouse on Acer laptop with Windows 7 but not seeing the device. Wireless button is on and active on the laptop
Wireless button on laptop has nothing to do with wireless mouse. Plug in your mouse receiver that come with the mouse in to a USB port on your Laptop. Turn on your Mouse and hold the reset or sync button on the bottom of your mouse for a few seconds, so that the receiver can synchronize with your mouse. Mouse should now work OK
Jan 04, 2011 | Logitech Cordless Mouse
I have a Logitech wireless mouse DH931435 that has started to give me problems....the scrolling wheel only turns one way with great difficulty and the right and left click are very stiff....what can I do?
It sounds like someone spilled pop or other sticky stuff on the mouse. Its pretty easy to clean. Should be a couple of screws on the bottom. Take them out and carefully remove the plastic pieces. As long as you go slow are remember how it all fits together you will be just fine. There are a couple of small pieces that will fall out (if its an older mouse) so just be cautious. Use some rubbing alcohol and q-tips to clean around where the buttons press down and where the wheel rotates. Then put back together and it should work fine. Remember to do all this with it unplugged.
Good Luck
Jul 08, 2010 | Logitech (931395-0403) Mouse
Mouse left button double clicks all by itself about every other time it is pressed. Very annoying. May be an internal contact problem, but don't know how to open it up to check.
Recommend you check your mouse settings on your computer (i.e. mouse properties buried in control panel settings as found on Windows XP); make sure double-click speed is not set at an over-sensitive setting.
Might also check there is nothing sticky under the mouse key, causing it to get stuck (e.g. splashed soda pop or something that got under there).
Feb 10, 2010 | Logitech Wireless Mouse & Keyboard
MX600 Logitech laser cordless mouse, left button stops working
Just found a temporary solution (fixes the immediate problem, but it does return):
Turned the mouse off held down both buttons, turned it on, let go of both buttons. When you let go, it works again.
Jul 02, 2009 | Logitech MX 600 097855036162
Wireless Optic Logitech mouse performace
I had the exact same problem with my original Logitech wireless mouse that came with a wireless keyboard. I eventually figured that the button component inside the mouse wasn't making consistent contact causing unintended double clicking or dropping while dragging. I fixed it by doing some soldering to switch the left mouse button with the right mouse button, since I didn't have to use double clicking or dragging with the right mouse button. It worked pretty well for several months until the switched left button started showing the same problem again. Now my newer Logitech mouse (it's more expensive Nano wireless mouse) is having the same problem after about 1 year using it. I think there's a serious durability problem with the button component that Logitech is putting on their mice. I may do the same trick again on this mouse, but now I don't consider Logitech as a good mouse manufacturer anymore. They used to make good quality hardwares but I guess they aren't that good anymore with all those cheap Chinese suppliers for their parts. :(
Apr 28, 2009 | Computers & Internet
Wireless keyboard locked
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Aug 26, 2008 | Logitech LX 700 9674180101
Logitech wireless optical mouse problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Aug 03, 2008 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
Logitech LX7 Cordless Optical Mouse Logo
3,749 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
