1991 Acura Integra Hatchback Logo
Jerry Chirip Posted on Aug 09, 2009
My passenger seat belt is automatic but it is not working,what do i need to do to fix it?
Anonymous
Level 1:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Sep 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
281
Points
My seat belts stopped working last summer, i was inthe same boat. . . howerer, i learned that seat belts are mandatory equipment, and there for they have a life time warranty. just make an appointment with the dealer, and they fix it free of cost. heck my dealership even rented me a nice car to drive while the fixed my car. go for it!
Remove seat belt
Hi Ray, Removal of the seat belts requires removal of the seats. Adjust the front seats to the fully backwards position and remove the fixing bolts and then unhook rails at the rear.You will notice a wire cable attached to each seat used to adjust the belt shoulder hight. This must also be disconnected. On later model vehicles there is an automatic retraction unit which pulls the driver and or passenger back into the seat in the event of the air bags being deployed. These connections must also be removed. If seats are electrically operated unplug all connectors. Remove seats and then gently remove plastic door pillar covers. (These are in two pieces for each front belt.) Removal will leave the fixing bolts of retractable part of the seat belt exposed. The buckle side is fixed with one bolt and has an electrical connection which must be disconnected. Hope this is of help? Regards John
1helpful
91 honda ex, passenger front seat belt is not working and the light in the dash board keeps lit, I have check the fuses for it, and all the connection to the belt and it seems all intact...any advise?
Your 1991 model Accord has automatic front retracting shoulder belts and, more than likely, the power retractor motor has gone bad on the passenger side front. If the shoulder seat belt is not in the retracted position, up close against the seat, when the car is running, the seat belt light will stay lit on your dash. Have the seat belt motor inspected and replaced if necessary.
2answers
I have a 2002 Honda Accord EX-4. The SRS light came on and stayed on. I've owned the car since new, and it's never been hit.I have three questions 1.) Could it be something with the seatbelt? 2.)If not,...
Here's a quick check list for most common cost of SRS / Air bag problem.
Dirty contacts on driver and passenger seat belt buckles
Dirty contacts on seat belt connectors (under seats)
Dirty contacts on driver and passenger sides weight sensors (under seat)
Seat covers
Weight on passenger seat
(Example: grocery package trigger SRS / Air Bag light on the way home.)
I recommend you to pass an vacuum over the contacts and use CRC electronic parts cleaner to rule out connectivity2_bing.gif problem.
I DO NOT disconnecting the negative battery connector to clean the code(s)
Without the code(s) the dealer will takes "BILLABLE" time to reproduce the problem.
Please rate me answer if it is useful to you.
Cheers,
Mustgo
1helpful
2answers
1990 CAMRY - Automatic shoulder belt doesn't operate
right thinking, check the fuse then the relay.that's what it is most of the time.
I NEEDED THE 2001DODEGE CARAVAN SPECIFICATION
2001 Dodge Caravan Performance Features -3,301 cc 3.3 liters 6 V engine with 93 mm bore, 81 mm stroke, 9.3 compression ratio, overhead valve and two valves per cylinder
-Unleaded fuel
-Fuel economy EPA highway (l/100km): 9.8
-Multi-point injection fuel system
-Main 76 liter unleaded fuel tank
-Power: SAE and 134 kW , 180 HP @ 5,000 rpm; 210 ft lb , 285 Nm @ 4,000 rpm
2001 Dodge Caravan Handling & Driving Features -ABS
-Two disc brakes including two ventilated discs
-Spacesaver steel rim under body spare wheel
-Strut front suspension with stabilizer bar independent with coil springs , beam rear suspension with stabilizer bar rigid with leaf springs
2001 Dodge Caravan Exterior Features -Body side molding
-Front and rear body color bumpers
-Driver and passenger power heated black door mirrors
-External dimensions: overall length (mm): 4,803, overall width (mm): 1,996, overall height (mm): 1,750, wheelbase (mm): 2,878, front track (mm): 1,600, rear track (mm): 1,626 and curb to curb turning circle (mm): 11,460
-Complex surface lens halogen bulb headlights
-Double sliding minivan side door
-Remote control operation opening rear ¼ windows
-Metallic paint , gloss paint , pearl paint
-Fixed rear window
-Tinted glass on cabin, rear and side
-Weights: curb weight (kg) 1,842, gross trailer weight braked (kg) 907 and max legal load (kg) 772
-Windshield wipers with variable intermittent wipe
2001 Dodge Caravan Interior Features -Air conditioning with rear outlet
-Fixed mast antenna
-Manufacturer's own audio system
-Automatic drive indicator on dashboard
-Below seat storage under passenger seat
-Cargo capacity: all seats in place (liters): 433, all seats removed (liters): 4,154 and third row seats removed (liters): 1,291
-Clock
-Dashboard full console with open storage box
-Delayed/fade courtesy lights
-Cruise control
-Front seats, rear seats and 3rd row seats cup holders
-Door ajar warning
-Door pockets/bins for driver seat and passenger seat
-Floor covering: carpet in load area
-Driver and passenger front airbag
-Bucket seat
-3-point reel height adjustable front seat belts on driver seat and passenger seat
-Front seat center armrest
-Glove compartment
-Height adjustable two head restraints on front seats, rear seats and 3rd row seats
-Internal dimensions: front headroom (mm): 1,011, rear headroom (mm): 998, front hip room (mm): 1,440, rear hip room (mm): 1,722, front leg room (mm): 1,031, rear leg room (mm): 930, front shoulder room (mm): 1,588 and rear shoulder room (mm): 1,643
-Low fuel level warning
-Low washer fluid level warning
-Internal button power locks
-Power steering
-Front power windows with one one-touch
-Front reading lights
-3-point reel height adjustable rear seat belts on driver side and passenger side
-Bench one-piece two rear seats
-Rear view mirror
-Upgraded cloth/velour seat upholstery
-Seating: seven seats
-Six speakers
-Plastic steering wheel
-Tachometer
-3-point reel third row seat belts on driver side , 3-point reel third row seat belts on passenger side , lap static third row seat belts on center side
-Front facing bench removable one-piece third row seats with capacity three
-Driver and passenger vanity mirror
-Ventilation system with recirculation setting
Thanks.
2helpful
I have a 1993 saturn sc and it has automatic seatbelts that go across you.. and the drivers side works fine but the passenger side will not work. it stays up and when i close the door it is supposed to...
It Needs Either a New Seat belt track assy. on the side that's not working or a new Seat Belt Control module Located under center console (Blk Box With 3 Connectors) One Fuse works both tracks
How do we fix front passenger side seat belt retractor on 1999 Ford Taurus? It will not pull out....
you may have to remove the bolt that holds the buckle to the floor. Try to push the belt into the retractor and see if it frees up.
I assume you are saying it is in the locked mode. It has an automatic lock mode for holding a child seat. When the belt is pulled all the way out, it goes into locking mode. You will hear it ratchet when the belt starts going back in.
Section 01-20A: Restraints, Active 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Safety Belt, Lap/Shoulder The dual locking mode retractor on the shoulder belt portion of the combination lap/shoulder safety belt for the front seat passenger and rear seat outboard passengers operates in two ways:
  1. In the vehicle sensitive (emergency locking) mode, the shoulder belt retractor will allow the occupant freedom of movement, locking tight only on hard braking, hard cornering or impacts of approximately 8 km/h (5 mph) or more. The front and rear outboard seat belt retractors can also be made to lock by pulling/jerking on the belt.
  1. In the automatic locking mode, the shoulder belt retractor will be automatically locked and remain locked when the combination lap/shoulder safety belt is buckled and does not allow the occupant freedom of movement. This mode provides tight lap/shoulder belt fit on the occupant and on a child safety seat or infant carrier installation restraint.
  1. When the combination lap/shoulder belt is unbuckled and allowed to retract completely, the retractor will switch to the vehicle sensitive (emergency) locking mode.
sxh~us~en~file=ani_caut.gif~gen~ref.gif WARNING: REAR-FACING INFANT SEATS SHOULD NEVER BE PLACED IN THE FRONT SEATS.
The automatic locking mode must be used when installing a child safety seat on the front passenger seat and rear outboard seats where dual locking retractors are provided
Seatbelt holds passenger tight in seat all the time, 2002 tahoe
There is no fix for this, u will need to replace the seat belt.
3helpful
2answers
1991 CIVIC LX AUTOMATIC SEATBELTS NOT WORKING.
I had a problem on a 91 Civic DX where the drivers auto seat belt wouldnt move and the beeper would not stop.Had a blown seat belt fuse.Replaced the fuse no more problem. The Seat belt fuses are located under the red cover that covers the positive battery terminal. On mine the fuse closest to the font of the car was for the drivers side auto seat belt the one closest to the windshield is for the passager seat belt. They are green and rated at 30A.
Top Acura Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Acura Expert? Answer questions, earn points and help others
