Question about Sony Televison & Video
Can't Open DVD Player
Somehow the child lock was set to "on" on my Sony DVP-NC85H player. I'm following the instructions in the manual and pressing "return," "enter," and then "power." That's not working. I've also tried "stop," "eject," and "power" simultaneously, unplugging it for a few minutes and resetting to the default settings. What else should I try to get this to work?
  • Anonymous Dec 08, 2007
    I am having the same problem. The directions in the user manual are useless.
  • Anonymous Mar 25, 2009
    I have the same problem, Sony and other company are **** about this, they need to remove the feature completely. It should be up to parent to keep the child from opening the player.
This worked for me:
Don't bother with the tech support line. Take a philips screwdriver and remove the 2 large screws on the sides of the unit, then the 3 screws in back that attach the shell to the main body of the unit. Slide the shell back. You can now access the DVDs that your Sony player has kidnapped.
This is totally ghetto, but you CAN change discs now. I bought the unit for $99, and tech support wanted me to ship the unit on my own dime, plus pay $99 for a refurbished unit, PLUS shipping back to me. This was their best solution. :|
You can try unplugging the wires/cables inside and then re-inserting them, but it didn't work for me. I recommend turning the power off first.
I will probably use the changer this way for a while, but I'll be looking for a new unit to replace it with.
I really thought I was safe buying this big name brand, and the unit served me well for 2 years... Next time I'll do more research first, because this seems like a common issue.
Posted on Jan 17, 2009
Try holding down the power button for 5-10 seconds until it turns on. Worked for me.
Posted on Jun 22, 2008
SOURCE:
Has anyone ever solved the 'locked' tray problem on a Sony DVP NC85H?
Look on the bottom of the unit. There is a hole with the letters ex and op. Shine a light in the hole and you will see a white plastic object with a slot for a slot screwdriver. You can turn this either way but be careful. If you feel resistance and the object does not turn, turn the other direction and the unit will open. Op is open. Ex is exchange.
Another less elegant way is to open the unit's case, take off top cover and get your discs being held inside the unit that way. Be careful.
Of course you could take the unit in for service but may not be worth the cost.
Mar 13, 2011 | Sony DVP-NC85H Multi-disc DVD Player
The "L ch" message is
To cancel child lock in DVP-SR200P dvd player, press power button to turn unit Off (standby mode) then press Return, Enter and Power buttons on remote.
This will cancel child lock in dvd player.
Hope this info will help you.
Thanks.
Nov 03, 2010 | Sony DVP-SR200P DVD Player
Cd compartment wont open and it is locked dvp sr200p sony
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Jul 26, 2010 | Sony DVP-SR200P DVD Player
Every time i try to put in a disk, it says its locked
Yes,Some one have set the child lock ON accidently.so it appears as LOCKED
As this child lock is ON you cannot open the tray.
Please follow the below steps to open child lock,
When player is in standby mode press RETURN,ENTER and then ON/STANBY BUTTON again.
You can open it.
If it appears as TRAY LOCKED ,You should contact your sony dealer or authiorised sony service centre.
Thanx
Jul 26, 2010 | Sony DVP-NS315 DVD Player
Unlock Sony DVP NS725p
Ensure the child lock feature is disabled. Attempt to open the disc tray. If the issue is not resolved, turn off the DVD player. Unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet. Attempt to open the disc tray. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons. If the issue is still unresolved, service may be required. The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jul 24, 2010 | Sony DVP-NS725P DVD Player
Cant turn my prgressive scan off so cnt watch or use sony dvd player
Put dvd player in standby mode and press 3,6,9 buttons on dvd remote to turn off progressive scan off. Let me know exact model number of your dvd player if above solution does not work.
Jun 15, 2009 | Sony DVP-NC85H Multi-disc DVD Player
SONY DVP- NC85H
I am getting this error too and I believe it means that somehow the tray that the discs ride on is jammed. I think if you unscrew the three screws on the back and the two on the sides you can pop the top off and see the tray. I bet there is a disc somewhere that didn't fall back into its right spot and it will give you that error... I just opened mine up and sure enough there was a DVD that was in the way... I removed that disc and the error went away. I hope that helps you out as well.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Not able to turn off Progressive scan feature-sony dvp nc85h
If it works like my sony RDR-GX315 just press the pause button on the player itself and hold for 5 seconds.
Jan 08, 2008 | Sony DVP-NC85H Multi-disc DVD Player
DVP-NS305 DVD Player
Your system is in child lock mode. I had this exact problem this week. You need to put the system into standby mode and then press return, then enter then on/off and it will be unlocked.
Aug 28, 2007 | Sony DVP-NS305 DVD Player
Televison & Video Logo
300 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
