Question about Western Digital Caviar SE WD1600JS (WD1600JS20PK) 160 GB Hard Drive
Making boot copy
I have a wd 160 gig hard drive I want to have as a back up copy.
It is installed as a slave, I formatted it partitioned it and try to copy the boot drive using the software, it will not copy. What do I have to do to make this happen
  • 657 Answers
SOURCE: Trying to format a 500GB HDD at full capacity
sounds like the SATA - PATA converter doesn't accomodate for a 48 bit LBA (to handle disks of more than 137 GB)
you need to get the correct converter, as this one is not compatible, you should be able to return the converter as not fit for purpose (needs LBA 48bit).
Posted on Oct 11, 2007
  • 8596 Answers
SOURCE: installing SATA WD 160 GB Hard Drive
You may not have a SATA system - Western Digital has the other type of hard disk drive available.
Posted on Apr 07, 2008
SOURCE: Formatting and Partioning WD My Book for Mac OS X
what are the tips of hard disk drive troubleshooting
Posted on Jan 08, 2009
SOURCE: Installation instructions and drives WD1600JB hard drive download please
not able to use disc that came with hard drive computer shows it's there but doesn't regester using as a second drive
Posted on Jan 10, 2009
SOURCE: How do I completely remove the WD Sync software
Assuming you are using XP, Vista, or 2000 you can format it as a NTFS drive. while a lt of folks do not like Vista, this is one area where it really shines.
Plug in your WD PASSPORT.
Bring up the START menu -> right click COMPUTER-> select MANAGE -> select STORAGE ->select DISK MANAGEMENT.
Find the dive -> select/highlight the WD PASSPORT -> right click and select FORMAT. make sure to format as an NTFS drive. Depending on the size of the drive this might take a while - so go have dinner and a movie.
Posted on Jul 19, 2009
  • 59 Answers
SOURCE: Western Digital Reset / Set Hard Disk Size ?
hit F1 when you bootup dont let windows come on . Go in you Biso to set you new hard drive.dont forget to F10 to save changes...Good Luck
Posted on Aug 16, 2009
0 characters
1 Points
Tell me how to make it one of two partitions of primary slave
if you are trying to install a dual operating system with 2 hard drives and if your hard drive are sata
the largest will automatically become the primary
if you need to make a partition on one hard drive
partition magic would be the program for you and its 100%free,0.aspx
when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Nov 06, 2011 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
External hard drive not detected
Check your jumpers on the hard drive. DON'T leave it connected very long if the jumpers are not set for master / slave (furthest away/ closest to the IDE port on the computer or it can mess up the circuit boards on one or both drives! If you are using only one hard drive, set the jumper(s) for "cable select" (often abbreviated CS). If it still doesn't detect the drive, the drive may not have an "active" partition on it. You can solve that by booting to your OS installation CD -- assuming you have one!
Feb 02, 2010 | Western Digital Elements powered by WD 320...
I have a motherboard that has only has one ide conncetions
what you should do is make the 300 gig as second drive and your primary drive is the 80 gig so that you can view and back-up the contents inside it. If you going to install a new copy of Operating system that would be in the 80 gig so that you don't need to format your 300 gig and make it as second drive. Hope this could help you..Thanks..
Oct 24, 2009 | Hard Drives
Win98 hds in win xp dont show other program says not formatted
you will need to revert back to the master/slave setting.  As slave/slave neither disk will be the main controller. Try reverse the master disk to the slave, and the slave to master, as it may be that the controller has a fault which is why you were having the original win98 problem.  Let me know how you get on
Jun 20, 2009 | Hard Drives
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
External hard drive disk space
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
Aug 17, 2008 | Western Digital My Book Essential Edition...
Formated Hard drive from Ebay
Apparently you have tried most if not all of the basic install procedures.
If and when you connected it as a secondary or slave to a working/booting PC, was it auto detected at the CMOS/BIOS stage? If yes, then perhaps it is a partitioning/formatiing issue, if not then chances are that it is a hardware problem and the drive is dead.
Alternately, you can try using an external SATA/IDE Interface to USB such as a VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter or any comparable product. This would provide the SATA/IDE connections to your new hard drive as well as a USB cord to your PC's USB port.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 14, 2008 | Western Digital Caviar (WD307AA) 30.7 GB...
Seagate barracuda7200.9 80 gig.
Some of the following answer assumes a windows operating or possibly DOS based operating system. If your original OS was not Windows or DOS -- there may be different considerations.
1) Did you lose the contents of both partitions?
That depends were they soft or hard partitions.
Soft partitions are created as files inside of other partitions
If that is what you had allocated in the formatted partition
you have lost their data content.
Hard or physical partitions allocated using FDISK and some other utilities the second partition would still exist.
2) Where are/were your system files. Often but not always they appear as the first partition of the master drive on the primary IDE controller all assuming a PC (based on the master slave comments you have indicated.) (sometimes the second when diagnostics are loaded on the first partition)
a) if the partition on the drive you formated contained the system files yes they must be installed to access anything on the disk for the most part. A significant exception may be utilization of a DOS boot diskette might permit DOS access to the other partitions if they are formatted with the FAT file system.
NTFS partitions and possibly FAT32 partitions may not be accessible to all versions of DOS -- there may be some bootable CD's that would allow access to NTFS partitions without installing an operating system.
Question back from the DOS and older version of windows days and even some more modern operating systens in subsequent actions with the disk did you use FDISK or another utility to rewrite the boot blocks to point to a different partition?
Question this was not a dual boot machine was it?-- if so disregard anything that follows.
Question did the machine boot after formatting the partition and before you started moving the drives around? If so the operating system is probably on a drive you have removed from the machine. It needs to be replaced onto the same cable position it was originally located upon -- probably on the Primary IDE cable master position or jumper setting.
If not reinstallation of the operating to the formatted partition is probably the correct next step. Be careful in doing this because if you choose one of the other partitions that were not formatted it could wipe out the data in them based on the installation process chosen.
Dec 10, 2007 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Copy Problems
It's not a question of re-formating...It's a question of Partition...FAT32 does not allow files over 4gb to be stored...You have to convert the partition to NTFS..There are tools for that on the WD website....Try to do some research about the pros & Cons of NTFS..because you wont be able to go back to FAT32 without formating....
Nov 17, 2007 | Western Digital My Book Essential Edition...
160 gig external storage
Plug In your external drive! if you have any data back it up!(you said it was new so i assume there little to none) Go to start->run type diskmgmt.msc In the bottom pane look for your external drive! If there is a partition, right click and delete! Now the drive should appear full black on disk management! If not delets any other partitionin the drive. (Make sure you are deleting the external drive partition(s)) Now you can create drives by right clicking on the drive and click create partition! It should bring up a wizard which gives you the option to format, set partition sizes and everything!! If you don't wanna go through all that check out a third party software called Partition Magic: hope this was helpful, regards, babb
May 07, 2007 | SimpleTech SimpleDrive...
Western Digital Caviar SE WD1600JS (WD1600JS20PK) 160 GB Hard Drive Logo
57 people viewed this question
Top Western Digital Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Western Digital Hard Drive Expert? Answer questions, earn points and help others
