Question about LG WM1814CW Front Load Washer
Lg wm1814cw drain error
Hi today my washer started blinking OE and says drain error see owners manual which ofcourse i don't have please help
  • cdrollout Nov 11, 2008
    Same problem. I cleaned out the drain filter and made sure the drain hose was not bend.
  • Anonymous Mar 19, 2014
    will not drain water
Wm- 12225fd
Posted on Dec 11, 2007
    President:
  • 1,294 Answers
Click on LG (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Posted on Nov 28, 2007
  • prem mathew Nov 28, 2007
    Sure your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Plug off the wall first. Good luck, & dont forget to rate me......
SOURCE:
Wm1814cw will not drain oe error
oe on your machine means your pump is not emptying empty the machine manually and clean out your pump it should work then
May 23, 2013 | LG WM1814CW Front Load Washer
We have a LG frount loader and just moved house and now it seems to me stuck middle cycle the message comes up isOE I have checked it is level water is on and the machine runs for 5 mins or so then stops...
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jan 15, 2011 | LG WM1814CW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
The OE Message on my LG Tromm WM1814CW
Open the little trap door on bottom front of unit. Unscrew lint filter trap. Drain water first with small tube.
Sep 08, 2017 | LG WM1814CW Front Load Washer
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
I have an error message on my LG WM1814CW washer The message
This means the machine did not drain within a 10 minute time period. check the pump trap for debris and clean out. Check the drian hose. Check for drain pump operation diring drain period
LG WM1814CW
I thank you for your support on fixing my OE error. I cleaned out my filter on the bottom left hand corner of my machine. Problem fixed. Be aware that when you unscrew your filter, you may have a lot of water draining.
Sep 21, 2008 | LG WM1814CW Front Load Washer
LG wm1814cw washer
No, there is no access to the drain pump other than by removing the front panel to get to it.  It is a job that can be done but you will need to spend some time to disassemble the machine to get to it.
Sep 04, 2008 | LG WM1812C Front Load Washer
LG WM1814CW Front Load Washer Logo
488 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
