Question about Frigidaire ATF6000ES Front Load Washer
Wiring a grounded plug to a dishwasher
Is there a specific way to connect the b/w wires to a pigtail plug? can the w/b be connected to either of the copper wires
  • 883 Answers
Not rellay, Black wire is HOT leg and WHITE wire is neutral...reversal may trip breaker at house panel or worse, damage machine. On the plug, the wider (or larger) brass connector that gets plugged into wall outlet is neutral...white.
Posted on Nov 28, 2007
Our dishwasher has two grey and one green wire but the instructions say there should be a white, black, and green one. How do we figure out which wire is which?
The green is the earth. If the other two are the same colour, I guess the polarity positive and negative doesn't matter. What does the Bosch installation instructions say?
http://www.doityourself.com/stry/220-wiring-color-code-interpretation
Dishwasher GFCI Requirement ' Electrical Construction ...
ecmweb.com > Forums > Electrical 101 > National Electrical Code (NEC) Mar 4, 2014 - 18 posts - ‎13 authors Sounds like I have to install a GFCI breaker to protect the entire branch ... National Electrical Code (NEC) > Dishwasher GFCI Requirement ...
Dishwasher: Hard Wiring Vs. Plug-In ' Home Guides ' SF Gate
homeguides.sfgate.com > ... > Other Types of Mortgages When you install a pigtail on your dishwasher, you must plug it into a three-prong receptacle. The electrical code does not require the receptacle to be a ground ...
Installing a dishwasher- Does it really need a dedicated ...
forum.mrmoneymustache.com/.../installing-a-dishwasher-does-it-really-n... Mar 12, 2014 - 15 posts - ‎12 authors Installing a dishwasher- Does it really need a dedicated circuit? ... "If your local code requires it on a separate breaker, then put it on a separate ...
electrical - What is code for installing a dishwasher in the ...
diy.stackexchange.com/.../what-is-code-for-installing-a-dishwasher-in-th... Mar 14, 2013 - Current code suggests a dedicated line run to the breaker box for use with the dishwasher. 2008 NEC indicates that the kitchen should have ...
What is the typical dishwasher/disposer electrical connection?
diy.stackexchange.com/.../what-is-the-typical-dishwasher-disposer-electri... Dec 11, 2013 - Checking the wiring for the disposal, might give you some clues as to ... Code that allows Garburators and dishwashers to be cord-and-plug- ...
Dishwasher Connection And Wiring, Oh Boy! - Electrical ...
www.diychatroom.com/.../dishwasher-connection-wiring-oh-boy-10656... Jun 4, 2011 - 15 posts - ‎9 authors Q: should I hard wire the dishwasher or install a receptacle and wire the machine with an appropriate cord and plug? The code says you can do ...
Feb 28, 2016 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
It has two grey and one green wire but the instructions tell us black, white, and green
Feb 28, 2016 | Car Audio & Video
How to connect 4 wire pigtail to 3 wire dryer
connect directly to dryer. There should be a connecting block in back of dryer marked for blk.hot wire,white commen wire,and Green or bare ground wire & add another ground wire from a screw on dryer to green ground wire at the block.To be safe,check your owners manual. PS always be sure your pigtail is unpluged.first.
Sep 27, 2014 | Whirlpool GEW9250 Electric Dryer
Kobalt 60 gal compressor 221565 book saYS NOTHING ABOUT WIRING PIGTAIL 240 VOLT I WIRED IT LIKE I THOUGHT IT WENT AND BLOWS BREAKER WHEN I PLUG IT IN HELP!!!!!!
266549_300.jpg This is the most popular switch used on compressors but may not be exactly what you pressure switch looks like. You will need to determine how the contacts transfer power across the terminals. Lets number the terminals from left to right 1,2,3,4. On this switch notice how power crosses from 1 to 2 and from 3 to 4. You can determin how power is transfered on your switch by using meter. On this switch, leads from motor (load) would be connected to 1 and 4 and line in ()would be connected to 2 and 3. Determine with meter which leads from your pigtail are 115v each. Pigtails have either 3 or four wires depending on your wall plug configuration. You will only need the two 115v lines (connected to 2 and 3) and a ground wire connected to green screw. Under the cap of the pressure switch, there should be a wiring diagram to assist you for your particular switch. Good luck
Mar 18, 2011 | Air Tools & Compressors
How to connect a four wire pigtail
The white wire goes to the middle terminal post on the dryer.
The red and black wires go to the outside terminal posts.Doesn't matter which.
The green ground wire needs to be attached to the outside metal case...anywhere. The easiest way is to put the eyelet on the screw that attaches the terminal cover plate when you put it back on. Sandwich it between the screw head, the plate and the case.
Hope that helps. Let me know if you need more info
Best, G
Aug 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
It's not getting any power to it, but the outlets are working.
most dish washers do not come prewired for power connection. customer or installer provides "pigtail" the part you plug in. Unplug unit, remove kick panel,, follow pigtail to connection bod and remove cover. cut off wire nuts, restrip wires and install new wire nuts
Aug 26, 2009 | Maytag 24 in. MDBH950AWS Built-in...
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
May 21, 2009 | 1992 Saturn SL2
How do you install the frd03-dvd? mines came with no instructions.
Hello jeffery_armi,
The FRD03-DVD allows you to replace the factory head-unit and retain the audio and power to your OEM DVD player. With the FRD03-DVD, the audio from the OEM DVD player is connected to the auxiliary input of the aftermarket radio to allow the DVD audio to be heard over the vehicle's audio system.
The FRD03-DVD harness consists of a molex-plug, stereo RCA audio male connectors, and red and black wires ending in "pigtails".
1) Connect the molex plug into the OEM harness.
2) Connect the RCA audio connectors into the "AUX" inputs of your aftermarket head unit.
3) Tap the red "pigtail" wire into the "accessory" lead of the vehicle radio harness (also usually red).
4) Tap the black "pigtail" wire into the "ground" lead of the vehicle radio harness (also usually black). Alternatively, the black wire may be terminated with a ring terminal and secured to a metallic ground nearby.
Hope this helps.
May 13, 2009 | Pie Frd03 Aux/S
Over heating
unplug the cord plug and open up where the terminal strip is. check the connections. if you have a four wire pigtail connections are: the two outside wires to the two outside terminals on the dryer. the middle white to the middle terminal and the last wire goes to chassis ground. if you have a three wire pigtail, the two outer wires go to the two outer terminals on the dryer terminal strip, the center wire goes to the center terminal and there should be a jumper strip from the center to the chassis ground screw.
Dec 12, 2007 | GE Profile Harmony DPGT750EC Electric...
Frigidaire ATF6000ES Front Load Washer Logo
35 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
