Question about ASUS VW192S Monitor
Display Settings I have connected a longer lead from my monitor to the tower and it the settings seems to be hard to read, a bit scratchy and narrow. I was told to fix it to -personalize -display settings, and then set it to 1440x900 but my only options near high resolution is 1280x1024, 1360x768, 1600x1200, 1768x992... Please help
  • reegsw Nov 28, 2007
    Thanks, The text is now very wide however a lot easier to read.
  • 56 Answers
Go to your display setting and use the 1280x1024 option then click on the advanced button at the bottom of the window.
In that window click on the monitor tab and set your refresh rate to 70 or 72 Hertz.
Hope this helps
Posted on Nov 28, 2007
My Satellite P 15-420 yesterday failed to show the correct display but only to white display without anything starting with showers but when you connect eternal monitor it works proper. How can I solve...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
also
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Apr 14, 2011 | XFX NVIDIA GeForce 8500 Graphic Card
My display problem in layer
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also
also
hope this helps
Apr 01, 2011 | Computers & Internet
Display bright is too weak.......display can not be seen in sun light.....may be display ic problem
also
also
hope this helps
don
Mar 09, 2011 | Computers & Internet
Compaq s2021 monitor goes dim after 60 seconds even if browsing/using the computer. How can I keep it bright?
also
also
hope this helps
don
Mar 06, 2011 | Compaq Computers & Internet
Display drive error
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error also
also
hope this helps
don
Feb 28, 2011 | Computers & Internet
Display
also
also
hope this helps
don
Feb 25, 2011 | Foxconn FC-G31MXP-K Motherboard
Monitor don't work with my CPU
first check your system resolutions on settings of display settings. what is the resolution of screen. and check monitor supported resultion information is there on monitor manual. adjust display resolution if necessary. then connect new monitor.
First you check whether the new monitor displays your system starting screen. mean before booting into windows. some text in black color.
Jun 22, 2010 | Samsung SyncMaster 743B 17 inch LCD...
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
I am trying to connect an external monitor to my legacy PowerBook G4 laptop.  I have the original video adapter dongle that Apple provided, which goes from digital video to VGA.  I've tried different...
Since your laptop's display has a problem, that could indicate trouble elsewhere in the computer that is preventing you from adjusting your resolution properly. In fact, a shrunken display points more to a problem in the video processing, not in the display itself.
Dec 27, 2008 | Computers & Internet
ASUS VW192S Monitor Logo
247 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
