Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore 911-9359181 serial 1r260309r
I have a code f7 and cannot fine my manual, can anyone help? thanks richard
  • Anonymous Mar 20, 2014
    I have a kenmore 629.4576969 and am getting an f7 code. Anyone know what this is?
    Sniper:
  • 68 Answers
You can find my solution to the most common cause of the F7 problem at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have now shared this with over 1450 folks and most report success. I hope that it works for you too. You can also find my solution at my website:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
Please let me know if it works for you at hutchipop@yahoo.com
I am making a study of this problem. What is your model number and how old is your oven.
Posted on Nov 28, 2007
What is code F7
Hi
Thanks for using FixYa. Error F7 on your range means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 27, 2010 | Kenmore 48385 Electric Triple Oven
I have a Kenmore built in oven, it doesn't work. There is a code F7. What could that mean?
Hello there:
Here is the list of f7 codes for this oven and what they mean and what needs to be checked and fixed
F7 Function key shorted Replace touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Oct 05, 2010 | Kenmore Ovens
I recently installed a used Kenmore oven. After installation, I checked it's operation, everthing worked fine. Today, I am getting an F7 code and a beeping. What is the F7 code?
The F7 error code indicates that one or more potentiometers (burner switches) are not connected properly or that you have one or more failed potentiometers.
The specific details of this failure code are provided in the second image below.
This is an excerpt from the technical information for this range.
Normally, a service technician would be needed to conduct the troubleshooting and diagnosis for this type of failure.
If you are completely confident in your technical ability to safely unplug the range and access these potentiometers (54 in the third image example) you may be able to check for loose or broken wires that could be causing this code.
If no loose wires are found, then you will likely need to have a technician find and replace a failed potentiometer.
IMAGE1: http://media.fotki.com/1_p,wfdddkwdfrwkdtqxgtqsskgwtqkq,vi/gfwdtqtbrxgdkgqwqtb/1/1303472/5961857/image11662img-or.gif
IMAGE2: http://media.fotki.com/1_p,wfdddbrbbbbgfttxgtqsskgwtqkq,vi/gsfkbbsqqxgdtwdgbsg/1/1303472/5961857/image11663img-or.gif
IMAGE3: http://media.fotki.com/1_p,wfddfqsqwsbqtrwxgtqsskgwtqkq,vi/gtfggdrdwxgftrgbbtf/1/1303472/5961857/image11664img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 10, 2010 | Kenmore 47619 Electric Single Oven
I have a wall oven and get a code F7. Kenmore Model # 49469791, Ser # 8A56383390. I reset the breaker by turning it off and then turning it back off. What do I do now?
Hi
Thanks for using FixYa. Error F7 on your Kenmore means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC).Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 27, 2010 | Kenmore Ovens
I have a kenmore elite electric range and it is diplaying a F7 code what can I do to fix it.
f7 error code usually means stuck function switch on control panel. Need to check each button or switch to see which one is stuck
Mar 19, 2010 | Kenmore Ovens
Oven flashing F7 serial number is jgrp17bew288
F7 code
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced
Good luck and please rate 4 thumbs for the free answer
Mar 10, 2010 | GE Profile JT910SASS Electric Single Oven
Giving an F7 error code
There was a tag on stove that told on the error codes. Reset pad, it was somehow stuck. Thank you for your help!!
Cheryl
May 27, 2009 | GE JRP15 Electric Single Oven
F7 code on kenmore oven and beeps what do i do to turn it off
Nov 11, 2008 | Kenmore 42161 / 42169 Electric Single Oven
Kenmore Gas wall oven flashes F7 Code
Hi Indy2008,
I have helped over 1600 folks solve the F7 problem. The problem is usually with the touchpanel and not the ERC. My fix tells how to determine which part is faulty. Hopefully you will not need to purchase a new touchpanel, however, if you do, an internet search will lead you to lower cost sources.
Please let me know if my fix works for you. You can email me at:
hutchipop@yahoo.com
Regards,
Powerman
Mar 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
766 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
