Fisher and Paykel WA37T26G Top Load Washer
Problem for Fisher and Paykel WA37T26G Top Load Washer
Water leaks during final spin cycle only
By timrhyand on Aug 09, 2009
My washing machine leaks during the final spin only. It will fill, agitate, empty, rinse and spin, but only during the final spin does water start to leak from what appears to be the bottom center of the machine. We have taken off the top to see whats going on during the cycle and dont see any leaks from any visable hoses, pump, or drain. Makes no sense to me. Any advice?
Best Solution
posted on Aug 10, 2009
Very Helpful)
GodBlessU
Rank: Wiz  Washers & Dryers  Expert
Rating: 85%, 148 votes
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Fisher and Paykel WA37T26G Top
Questions and Unsolved Problems for Fisher and Paykel WA37T26G Top
Do you recommend Fisher and Paykel WA37T26G Top Load Washer?
Answer
Answer
I noticed a little water at the bottom of my washing machine after a load was done. Can anyone... (More)
Answer
I have a whirlpool washer and it wont stop filling with water. It fills to start the wash cycle and... (More)
Answer
I have a Fisher Paykel Model MKT GWL 15 US Product #96200-A. I read the other solution for this... (More)
Answer
Where is the hot water wash? Hot water starts up, but cold water over rides the hot resulting in a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fisher and Paykel WA37T26G Top...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
