Question about Buffalo Technology 750GB USB SATA 2.0 HD DS 750 GB Hard Drive
Disk continually locks up
First of all, I'm not sure this this is the correct area to post this. I have two 500 GB USB drives, (SATA Bridge) which were purchased in Japan, where I live, and from the day I bought them they won't stay mounted and working for more than a few hours. They are being used on a Mac that was running os 10.4.10, and 11, but is now 10.5. Strangely enough, if they are being continually accessed, like when copying a 150 GB file or permanently playing tunes form an iTunes library stored there, they work fine. But every now and again, when they are not actually being used, they lock up. It almost looks as if some periodic routine access form the OS is jamming them up, but anyway, it is a right pain. I formatted them various ways, but the problem persisted (currently they are Mac OS extended (Journaled)). I haven't been able to get any assistance here in Japan, where they are made!!(I believe) and I should really have taken them straight back to the shop but I couldn't believe two drives would fail so badly so often so I assumed I had done something wrong. Any ideas what is going on, or are they just duff products?
2 Suggested Answers
SOURCE:
  • 21 Answers
SOURCE: I have a new buffalo 1tb Ext HDD I need to
I believe you should opt for MAC OS Extended (journaled) because journaling if more reliable and fault resilience. You can get details on this partition type on http://support.apple.com/kb/ht2355
Posted on Jul 20, 2011
Testimonial: "thanks! that article helped me make a decision."
Shows up as "Initio Combo Device Class" not a "Disk Drive"
RESOLVED the ISSUE...!!
Hi, Yesterday I get into similar problem of having my USB Drive ( WD passport Elite 320gb ) not being detected by my PC and as soon as I connect to it, Initio Combo device class drivers gets loaded and Drive do not show up in the device list...!!
I tried several options.1. Freezed my hard drive for 12 hrs in the freezer. It did not help me today.2. I have opened the USB drive shell ( becareful, I have damaged it.. see the instructions before you try t ). You can find the 2.5' HDD inside and there will be SATA to USB bridge adapter. I was having doubt on this bridge unit as I read through several blogs.3. luckily I have a unused 2.5' Laptop HDD. So I have removed this bridge unit carefully and tried to connect to my HDD. If the bridge is good, my HDD must be detected right away..But it is the same problem.. It did not work.. Hence I have confirmed that it is the bridge problem..
4. I bought a Rs. 250/- ( 5$ ) 2.5 SATA casing that is available in the market to use the 2.5' SATA HDD through USB. ( actually I do not know where I can buy only the bridge..hence bought the entire unit..which is still cheaper )
5. From the new unit, I have the USB to SATA bridge, which I have connected to my WD HDD SATA USB hard drive... Bingo.........It is detected by OS and I have started copying my important data immediately...
6. This Unit comes with a casing ..hence you may continue using this case... But some units may not fit well..still the bridge is usable..!!
I GOT all my data..with just Rs.250/- ( $5 ) ..I am happy to try this on my own..!!
Good luck with your drive..!!
Jan 01, 2012 | Western Digital My Book Essential 500GB...
I have a new H HD directly from box. Had problem with the windows install. Re-format, delete all files from new sata HHD. Use disk from toshibu, restore back to out of the box state. Now, missing...
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
Jun 19, 2011 | Hitachi (0S00157) 500 GB SATA II Hard...
I have a Seagate ST1.2 8 GB drive in an I/O Magic enclosure with a flexible USB connector that stopped responding recently. I suspect the USB connection has failed, not the drive. I would like to recover...
Yes, the disk-drive can be "transplanted' into a new enclosure.
Just be sure that you buy the correct enclosure (SATA-interface if your disk-drive has a SATA-interface, or parallel-ATA if your disk-drive has a parallel-ATA interface).
Feb 01, 2011 | Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard...
Hard drive was a usb type taken out of caddie as not working when fitted to my pc gives a beep code one beep is the hard drive control dead
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 14, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
How do i use SATA to recover my data from my WD 500 gb mybook? you see my power source is working at all.
You dismantle the case and extract the hard disk. Then you take that disk and you put it in a desktop pc (you will need a SATA dat cable, a SATA power cable and 4 small screws tu secure the disk inside. Once it's installed just start the pc and open My Computer - the disk will be there, copy from it whatever you want.
Sep 16, 2010 | Western Digital My Book Essential 500GB...
I have had to reinstall my operating system and drives but now the Seagate 500 GB external is not recognized. What now?
Are you using eSATA for the External or USB. If it is eSATA you may need to get the respective drivers for your motherboard for it.
Jan 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB to Sata Ide drive
If your sata drive is new then you will have to fdisk and format it before the pc will allow it a drive letter even though you are using it through usb. Did your Usb to Sata come with a driver disk? You will have to run it before the drive will work.
Dale
Jan 02, 2009 | Western Digital My Book Essential Edition...
WD5000AAKS not recognized
take it apart and get a bridge cable called IDE to USB or ATA to USB.
Connect the cable to your PC and take out the files.
Jun 17, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
Not recognized on Mac
In my experience those enclosures are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure.
Oct 20, 2007 | Apricorn EZ Bus DTS (EZ-BUS-DTS-500e) 500...
Bought a new LaCie drive; isn't recognized by mac or pc
Lacie Porsche drives in my experience or infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. Hope this helps.
Oct 02, 2007 | LaCie 301103U 500 GB USB 2.0 Hard Drive
Buffalo Technology 750GB USB SATA 2.0 HD DS 750 GB Hard Drive Logo
96 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Ekse
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
