Question about Frigidaire FGQ332ES Gas Dryer
Changing gas dryer to propane
Have new fridgider front loading gas dryer need to change it to propane
  • 131 Answers
SOURCE: Older Frigidare Elite Dryer conversion
You'll have to contact Frigidaire to see if a conversion kit is available. Normally, it's just an orifice replaced on the gas valve.
Posted on Mar 10, 2008
  • 166 Answers
SOURCE: Natural GAs to Propane
Call Maytag or whirlpool!
Whirlpool makes Maytag now same company
They make a conversion kit!
ngafm at your service.
Please rate me before you sign out!
Posted on Sep 06, 2008
  • 2651 Answers
SOURCE: Converting natural gas dryer to propane.
yes youllneed to know the exact model of your dryer, then you can call the manufacture for a conversion kit. not going to be Available at hardware or plumbing supply,
Posted on Feb 27, 2009
  • 70 Answers
SOURCE: Cold dryer?
I would bet on a bad ignitor. An appliance parts store should help you thru the install. Should be about $20.00 for the part.
Posted on Apr 23, 2009
SOURCE: Convert Whirlpool dryer from propane to gas
I have a whirlpool dryer as propane and needed it converted to gas. I have the orifce -gas kit which consist of two parts. Which part do I use? Is it the one which screws in and mist hole is on the other end, or the other one it comes with that has the mist hole on the other side.
The one i placed was the later ( one with mist hole on the side)
Posted on Aug 02, 2009
  • 1776 Answers
SOURCE: I need to convert my gas dryer to propane. I
Here are the basics of the conversion process:
Make sure the gas is turned off and the dryer2.gif is unplugged from the power source. Extreme care needs to be taken when installing the kit and making the conversion, since there is a very obvious safety issue if the kit is not installed properly. The kit will consist of a brass fitting with a nylon pin sticking out of it. This is called the blocking pin. At the gas valve and regulator you will remove the plug on the gas valve (called a leak limiter) and replace it with the fitting containing the blocking pin that comes in the conversion kit. That will change the gas regulator pressure setting from gas to propane.
Next, you will have to change the orifice metering plug in the burner. This does just what the name implies... it meters the amount of gas that enters the combustion area. The fittings that come with the conversion kit (blocking pin and orifice metering plug) are made of brass, which is a soft metal, and since they are being connected to a much harder steel, make sure that the fittings are not overtightened. I generally use some pipe dope on the threads. Once the conversion is completed, you want to check for leaks. I generally mix up some soapy water and spray it around the fittings to check for leaks. Look for bubbling which is a sign that there is a leak. The last thing to do is to reassemble the dryer. Start it up and make sure that it is operating correctly and that there are no obvious smells that would indicate a leak. If so, shut down immediately.
These are the basic steps for a gas/LP conversion. If there is any doubt that you feel comfortable making the conversion, then I recommend that you contact an appliance technician for assistance. Hope this helped and best wishes.
Posted on Oct 02, 2009
Testimonial: "This is good advice. Thanks! How do you get to the gas valve and regulator?"
0 characters
1 Points
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Natural gas to propane
the pilot and/or burner orfices need to be changed.depending on your model the gas valve may also need to be converted.
Sep 27, 2007 | Whirlpool GGW9250PL Gas Dryer
Change my maytag dryer from propane to gas?
Go to an appliance parts store and get a conversion kit. It should have everything you need. Make sure you change the pressure regulator.
Sep 20, 2014 | Dryers
All dryers come new set up for NG, you have to purchase a kit to change it to propane.
Jan 28, 2013 | Dryers
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
Need to change from LP to propane. How do I get access
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
May 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet gas to propane conversion
no you definately need to change orfices from gas(line) to propane, call your gas supplier for a conversion kit or go to an appliance parts store and they will help you on this on this matter,don't try to start this unit after change-over if the orfice isn't right, i tried it and found out tooooooooo late
Apr 04, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
How do i change an estate TGDS740JQ gas dryer to propane
they have gas to LP conversion kits online. just google for it. Its not a tough job if you have mechanical experience, otherwise call a pro.
Nov 06, 2009 | Estate TGDS740JQ Gas Dryer
How to remove the front cover of my samsung front load gas dryer
take the top off first by removing the two screws in the back, then the five screws which hold down the door section. the door will lift off and then follow the instructions
Jun 08, 2009 | Samsung DV448AGE Gas Dryer
Converting from natural gas to propane
you need to change your orfice or you will have a big problem with flame
Jun 01, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Frigidaire FGQ332ES Gas Dryer Logo
81 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
