Question about JVC AV-56WP30 56" Rear Projection Television
AV56WP30 JVC Screen would go green and flutter but would correct with switching on and off as well as going from split sytem back to one screen. Now all I get is black screen with noise. Sometime the blue power light flashes as well....I thought it was the bulb (lamp) going out but not sure now.
  • poorolebob Dec 03, 2007
    this tv is somewhat a darkish green tint , i have tried to adjust the color but i havent got it yet , maybe its a bulb ?? The blue bulb or do you know.
  • bryanteuler Feb 01, 2009
    jvc av-56wp30 mine turns green when you turn it off and then try to turn in on like when you come in from work etc.
    i always have to turn it on and off several times to make pic come back on when the green just flickers seems like the blue and red projectors are off after turning on and off for a while it finaly turns the pic back on can anybody help with this what part do i need ???
    help please
    President:
  • 4,402 Answers
Gave the crt's a little rat-tat-tap be careful!!!!!!!!!!!!
There are other possibilities as well. Look at the front of the green projector tube and see if it looks like the cooling liquid has been leaking out or if it is not clear all across the screen.
could also be convergence ic's
Posted on Jan 31, 2008
SOURCE:
How to adjust the convergence on jvc av56wp30 hdtv
Start in the center of the grid and work you way out in circles....do small adjustments....its better to make several passes...Look on the tv repair tips page on www.TvRepairKits.com for more info.
Jan 29, 2013 | Philips Magnavox 9P6034C 60" Rear...
Trying to watch a dvd and my tv has a split screen..how do I get it off
You should be able to go back to the regular screen by hitting either the SPLIT button or BACK on your remote.
I hope this helps.
Apr 23, 2010 | JVC HD-52G787 52" Projection Television
Cannot disable split screen (DIST dynamic gamma)
the way i solved it is by holding down the menu and the volume(-) and the disabling the dis. That worked for me so you should try it.
May 16, 2009 | JVC LT-26X575 26 in. LCD HDTV
My 56'' jvc av56wp30 tv screen is doubled only twords top o screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 19, 2008 | JVC AV-56WP30 56" Rear Projection...
Double picture
*Screen Looks 3-D
*Colors wont align
Aug 31, 2008 | JVC AV-48WP74 48" Rear Projection...
Screen slowly turns blue...
I had blue lines showing up on my screen, then the other night my screen started to flutter the blue, bright to dim and back. So I followed this link to resolve the blue lines and the blue flutter was resolved as well. Hope this helps.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jul 26, 2008 | Sony KP-51WS500 51" Rear Projection...
The initial video screen flutters and is grey in color
try the switch in the back. move it to the left.
Jan 13, 2008 | JVC XL-MV303 CD Player
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC DVD player stuck in Split screen
the player is set to progressive scan mode.use relevant button on remote to reset to interlace mode. Duane,S/Africa
Mar 11, 2007 | JVC XV-N320 DVD Player
Jvc gd-v4210pzw screen problems
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. https://youtu.be/wUpnETSm6_k
Apr 25, 2017 | JVC Televison & Video
JVC AV-56WP30 56" Rear Projection Television Logo
101 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
