Question about Sony PCG-FR130 Notebook
Pcg-xg28 no display
Hello, my pcg-xg28 loads up and boots windows (i can here the startup of windows) but there is no video, the lcd has issues anyway so thats not the problem the matter is this morning the external monitor worked fine, then i took out the lcd for other reasons and now theres no video on the external monitor it shows that theres no signal going out to it, at this stage im clueless as to whats wrong any help would be great
thanks
  • 89 Answers
Either the video card is bad, or the memory is bad. Replace the memory first to see if that fixes the problem. Also, if capable, reseat the CPU, which is located beneath the Keyboard.
http://www.Computer-Repair-Today.com
Posted on Jan 11, 2008
Optiquest q71, display settings tied to user profile
Boot into safe mode ...not sure what windows version you have but Google boot with safe mode with windows version windows 10, 7 XP etc
You should see the bios before windows loads. If it turns black when windows is loading bad DIsplay settings or driver.
Dec 30, 2017 | Optiquest 17" DPT Q71-5 Monitor
Sony VAIO PCG-392L screenwith striped colors
Hook a spare monitor to the video output of the laptop, if picture okay! the LCD panel display is defective and most be replaced. But if symptom is the same on both screens it indicates a bad Video Graphic Card normally built into the motherboard.
Mar 19, 2012 | Sony VAIO PCG-505TR Laptop
They are flashing vertical lines in various colors as well as letters showing
hook an external monitor. if its the same problem, video card is the problem. if it has a clear display, then you need to replace the lcd.
Apr 09, 2010 | Microsoft Windows XP Professional for PC
Our acer 19in LCD monitor goes blank after initial startup and msg "Input not Supported" appears. Startup msgs are shown but once Windows XP starts, this error appears
Your resolution is set above what the monitor supports.
when computer is first starting up hit f8 to get to boot modes.
choose Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
When you are booted into windows you can then set your resolution to the highest that the monitor supports which is 1440x900
Let me know if this helps.
Mar 16, 2010 | Acer AL1916W 19" LCD Monitor
Sony Vaio PCG-K23 LCD Monitor will work with Ubuntu or at c:prompt but the instant Windows loads it goes black. I've uninstalled, fdisked, reinstalled and so on what seems to be 100 times to no avail. I...
hook the laptop back up to the external monitor, once it boots and has settled, I would like you to hold down the Fn key which should be at the lower left of the keyboard and tap the F7 key. This will toggle the video output from external to internal or both at the same time. I have never heard of an issue where Ubuntu will allow a video signal, but now windows. I hope this works for you.
Oct 09, 2009 | Sony VAIO PCG-K23 Notebook
Screen is white
You could have a video controller problem or a LCD screen problem, what you are seeing is the backlighting but no video information.
To check if you have a video problem, connect an external monitor to your laptop and bootup your laptop, if you see Windows booting up the external monitor then the video controller is OK, and your problem is the LCD screen or the video cable connection on the motherboard (may need reseating).
If you cannot fix the LCD screen then use your laptop with an external monitor.
Jan 28, 2009 | Sony VAIO PCG-Z1WAMP2 PC Notebook
Booting problems.
try right click desktop go to properties/display setting check that display is set properly go to advanced settings check out there if everything OK go to control panel/device drivers uninstall video drivers reboot it should boot with standard vga drivers check if display is OK then try loading your proper video drivers
Jul 27, 2008 | Sony (B99860307) for VAIO PCG-K series...
No Display - Screen says "NOT SUPPORTED"
Turn your computer on.
When the boot screen cahnges to black start pressing F8
You should get a Windows startup screen
If you see the Windows Logo loading page, then hit the reset button and tray again.
On the Windows Start page, select Safe mode.
Press enter twice and Windows will load
Go into display properties (right click on the desktop and you will see it on the menu)
A box will pop up, select the last tab (Display Properties) there will be a slider on the left side. Move it left to around 800x600.
Select apply and then close the window.
Restart Windows normally and it should be fine.
If not, post back and we will try something else.
Hope it helps =)
Apr 12, 2008 | Computers & Internet
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
105 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
