The TV works fine with other inputs (cable TV), right?
The laptop is plugged into the VGA port on the TV and the input setting is set to "VGA", right? (or does toy computer have an HDMI port that you are using?)
Is it a laptop or a PC?
If it's a laptop and the TV is connected correctly and functioning otherwise, you need to turn on the remote display port of your laptop. It's a key sequence that toggles from laptop -> external -> both.
If it's a PC, it might be a signal incompatibility. Try different resolutions or refresh rates.
Good luck.
Was this helpful?
Yes
No
Popular Solutions for Insignia 37" 720p Flat-Panel
My Plasma Insignia HDTV ( Not sure what kind) is showing pink static covering all of the bright...
(More)
My Plasma Insignia HDTV ( Not sure what kind) is showing pink static covering all of the bright parts of my tv.
while watching tv the screen goes black. the set is still on and so is the cable box. the remote...
(More)
while watching tv the screen goes black. the set is still on and so is the cable box. the remote doesnt work so i have to turn the tv off by hand. it also comes right back on when i hit the power button. any idea what is goin on.
i have an insignia tv and i cant find out how to program my comcast remote to it. i tried holding tv...
(More)
i have an insignia tv and i cant find out how to program my comcast remote to it. i tried holding tv then setup then the 9-9-1 and alternating between power and tv till it turned off like comcast said to. like an idiot i tried for 45 minutes and nothing, can you help
I have a 37 inch insignia and when I turn the power on, I get no picture, no sound, no nothing. I...
(More)
I have a 37 inch insignia and when I turn the power on, I get no picture, no sound, no nothing. I put the sleep timer on last nite and when i woke up it was still on. I turned it on and then a few hours later i turn it on and nothing...help
