RCA L32WD12 LCD TV HAS TOO MUCH GREEN IN PICTURE
Hi, my RCA 32 inch L32WD12 LCD TV has a problem with an over abundance of green in the picture. The whole picture is not too green, in fact most of the picture/pixels are great as they should be, but there are green splotches or patches of the picture that have way too much green showing in them. It tends to be in the whiter areas of the picture whatever is showing either hi def or standard def. It's like whatever part of the picture is green then all of those pixels show nothing but green, then it moves to another area depending on what's showing.
I would love to find out which module to change myself as I do have some repair/electronics experience. Thanks for your help!
Mark
  • 77 Answers
SOURCE: blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Posted on Jun 25, 2007
SOURCE: Samsung plasma PS42D5S
how do you adjust the voltage settings regardss dave
Posted on Jan 27, 2008
electronick
  • 505 Answers
SOURCE: LG 42PX3DCV 42 in.
Pixel misfiring (diffusion errors) are caused when the tv is not firing and erasing the pixels correctly. It can be caused by a number of things, usually a voltage or waveform is off somewhere. If you just bought the tv, return it and get another. If you are out of warrany, you can remove the back panel and run the tv to check the voltages. Don't touch the heatsinks! they're electrically hot and will zap you.. the voltages are labeled on the back of the plasma panel with a sticker. first check Vs and Va. sometimes you can check -Vy, Vset, Vscan and others if labeled on the board. If you have to adjust waveforms you need a very $$ o-scope and should get qualified technician to adjust. If a board is bad, its likely your power supply or Y-sustain pcb, and less likely your Z-sustain or contol (logic) board.
Posted on Dec 07, 2008
SOURCE: Green noise in black areas of picture
I'm sure you all thought of this but if someone does not state the easy fix then the easy fix doesn't get done.
I had the same thing happen to my Sam46inch1081, it just started doing it, no slow fade in over time.
I have cable with the HD box, all I did to fix it was unplug the power from the back of the hdbox, wait a few seconds plug power back in and have it reboot. Problem was solved.
Like I said, easy fix for me, don't know if this will help you, but ya never know.
Just thinking out loud here but maybe its not your tv but some other equipment you have added to it other than the hdbox.
Posted on Dec 23, 2009
  • 161 Answers
SOURCE: green pixels on dark picture areas on Sharp Aquos.
This may help, but at your own peril.
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Posted on Jan 15, 2010
Rca tv model l32wd12 ser #c342cj0a2. When you turn on green light will flash on and off and screen will flash. No picture or sound.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 28, 2016 | RCA L32WD12 32 in. LCD HDTV
Rca tv model l32wd12 sound no picture
You need to replace the mother board/main board.
Make sure you have a really good surge protector for ALL your electronic devices.
Feb 04, 2015 | RCA L32WD12 32 in. LCD HDTV
TH BUTTONS ON MY RCA 32 INCH TV WON'T WORK
If all do not respond the set likely has a keyboard lock feature---look to the owner manual and read it carefully.
Dec 09, 2012 | RCA L32WD12 32 in. LCD HDTV
When turning the tv on the on button just flashes green no screen comes on
I have that problem sometimes and find that the Green light flashes and a blank screen. I press the channel I want on the control and keep the button pressed for a longer time and the screen then comes on. This might work for you and you can only try.
Mar 06, 2011 | RCA L32WD12 32 in. LCD HDTV
32" inch LCD TV After half hours picture offset
Hi shyamkhairna,
Your problem is caused by bad t-con board. You may look online for the replacement like ebay.com and shopjimmy.com.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 20, 2011 | Sansui HDLCD3210 32 in. LCD TV
My rca l32wd12 tv has a black screen no picture no sound
good day. you may consult that problem to qualified technician to fix you problem
Jun 21, 2010 | RCA L32WD12 32 in. LCD HDTV
Plzzz help me!!!!!
Your defective has defective parts on horizontal section. You need to bring the tv to expert technician,
Jul 26, 2009 | RCA 32F531T 32" TV
TV won't turn on!
The failure on these LCDs is mostly with a defective power supply. It appears like the voltage is not enough to make it work.
I repair these power supplies, let me know if you require further assistance. You can also write to jah2mil@hotmail.com for more info.
Oct 12, 2008 | RCA L32WD12 32 in. LCD HDTV
Televison & Video Logo
300 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
