2wire Router
Problem for 2wire (1000-400108-001) Router
Can you hook router to router to expand connection
By johgsgsl on Aug 09, 2009
can you hook router to router to expand connection in home
Solution #1
posted on Aug 09, 2009
Not Rated)
bob_computer
Rank: Guru
Rating: 87%, 1361 votes
Yes you can but you must connect the router you want add as a secondary one to the computer without it being connected to the network and make changes to it. These vary from model to model.
A better option is to add a "switch" these are cheap devices that are trully just plug in and forget. plug one into your router and then just plug the rest into the switch.
They are available in a large amount of combinations from simple 4 port to 48 port or more
http://en.wikipedia.org/wiki/Network_switch
some of the info on here may be a little technical but it gives you the idea.
http://www.tigerdirect.ca/applications/category/category_slc.asp?Recs=10&Nav=|c:2786|&Sort=4
will give you an idea on prices but if you go with a switch or HUB as they are sometimes called then always get one with more ports that you need and if you can get one that covers gigabit speeds that will be more useful in the future.
If you still want to do the router thing then lookup the router model you want to use along with the words "use as switch" or "use as hub"
Was this helpful?
Yes
No
Popular Solutions for 2wire Router
Questions and Unsolved Problems for 2wire Router
Do you recommend 2wire (1000-400108-001) Router?
Answer
Answer
samsung wireless lan adapter unable to connect to 2wire204 wireless modem
Answer
I have a 2Wire 2701HG-B Gateway router. How do I check if UPnP is enabled?
Answer
Can I hook up a router with ethernet and wireless to my Westell Model E90-610030-06 DSL2+ Router to... (More)
Answer
I have a dovetail jig but dont know how to use it
Answer
My 2wire modem keeps saying cannot find an ATM thing and no matter what I do it will not conect to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
in , FL
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
