Question about Estate TEDS740JQ Electric Dryer
Estate electric dryer
I have an year old estate electric dryer and I went to press the start button and nothing happened, do you know if there's anything else that I could do before calling a repair tech?
  • Anonymous Nov 30, 2007
    I have the same problem. Does it tick like the timer is running? Mine does and I even feel heat, but it won't start. Any suggestions?
  • Anonymous Oct 06, 2008
    I push the button to start the dryer and nothing happens
  • 943 Answers
Hi thanks for the question i looked it up and the most likely cause for this problem is the thermal fuse located at the back of the dryer remove back panel and on the air duct you will see a small plastic piece with 2 small blue wires going to it replace this part but also clean all venting to the outside as this will cause this to happen the appliance doc
Posted on Sep 22, 2008
It is the fuse. I have had this washer for about 1year and a half and every other month for the last 6 months I have needed to replace the fuse. I guess it's time to get a new dryer with better quality!
Posted on Nov 01, 2008
Mine makes no noise what so ever. I have had mine for 6 months. I press the start button and nothing happens.
Posted on May 14, 2008
Same problem here. My dad is good at fixing appliances and looked at it, he took it apart and did some troubleshooting, turns out there's power going all the way to the motor but the motor doesn't work. Anyone have any ideas? Are there any fuses or circuit breakers that might have tripped causing the motor to shut down? New motor is about $100, so don't really want to spend the money until I know that's the problem.
Posted on Jan 19, 2008
SOURCE:
Whirlpool estate teds840jq2 dryer just stopped working. I can hear a clicking sound from the timer when the timer is turned to a setting but when I press the start button, nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Estate TEDS840JQ Electric Dryer
I press the start button, the light goes on but nothing happens
I had the same problem. It is the door latch. It cost about $150 to fix. I can't believe the tech didn't know it. It is very common for Bosch Dryers after about 3-4 years old.
Jul 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
I pushed the start button on my dryer.
i think it is your thermal fuse went out. one more thing check you circuit breakers it 30 amp duel breaker. some time one side trip and other side still on. i hope it help you.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
Dryer wont start
I would check the door swith first.
Jul 15, 2008 | Estate TEDX640JQ Electric Dryer
Malber dryer 2 years old
move the dial to the "off" position first; wait for beep; then move to the drying setting you want, and wait for another beep.
Jan 06, 2008 | Malber TD700 Electric Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Estate TEDS740JQ Electric Dryer Logo
180 people viewed this question
Top Estate Dryers Experts
Craig Butler
Craig Butler
Mike
Smitty
Level 1 Expert
Are you an Estate Dryer Expert? Answer questions, earn points and help others
