Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Inoperative oven electric elements
Oven electric elements inoperative , Top+Bottom Elements are OK. What Are the common problems with tis unit
  • 23 Answers
It could be contact problems where elements are pushed into in oven. Elements are usually plugged into heavy copper lugs at the end of both element ends. should look at manual for this unit to see how to remove and check for blackened ends. {Make sure to unplug before any work}
Posted on Dec 08, 2007
Troubleshoot ge range model # PHB9255SP2SS
sounds like the oven elements are OPEN not shorted.
Oct 09, 2017 | GE Kitchen Ranges
We have a ceramic top electric Frigidaire model GLEF378CCS. Neither the broil or bake elements work in the oven. Stovetop elements are fine.
check all wiring connections, if ok ohm out oven thermostat, if thermostat ok, ohm out oven elements and if ok, check voltage at oven elements. isolate problem.
Jan 25, 2011 | Kitchen Ranges
Neff u17 built-under causes fuse to blow on all the kitchen electrics a few seconds or minutes after the bottom oven is turned on. No problem turning top oven on. Have changed element in bottom oven with...
There could be a fault in the lower oven , or it could be overloading the circuit. add the watts of the two elements and divide by line voltage, this will give amps , now check the fuse rating amps , it must be higher than the oven. If that checks out ok the fault is in the oven.
Jan 03, 2018 | Neff U1721 Double circotherm Electric Oven
Top oven will not turn on elements, bottom oven turns on elements
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 10, 2009 | Whirlpool GBD307PR Electric Double Oven
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Jul 09, 2009 | Thermador SC302T Electric Double Oven
No heat on the upper oven bake and broil elements
I gather you are measuring voltage with respect to the chassis ground?
http://www.appliancepartspros.com/07-wiring-information-parts-for-maytag-cwe5800acb.html
Shows the internal wiring for the unit. The parts are rather expensive and some are no longer available.
Mar 22, 2017 | Kitchen Ranges
Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
Feb 29, 2008 | Frigidaire FEF336BC Electric Kitchen Range
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
144 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
