Question about Nokia 6016i
Noki 6016i problem
Can anyone tell me how to turn the power save mode off of this phone? I have been thru every single thing and i can't figure it out.. Thanks
Brandi
  • 4,102 Answers
Hi to turn the power save of you need to go into setting then display and then power save should be listed and you can deactivate it from their hope this solves your problem let me know how you get on ok
Posted on Nov 28, 2007
SOURCE:
Settings wont save. I CANT GETMY SETTINGS TO SAVE. I PUT IT DOWN GO DO THINGS COME BACK & LOOKS AS IF ITS TURNED OFF. THE BRIGHTMNESS SETTING ON ITS OWN GETS TURNEDVALMOST OFF & SAME WITH OTHER...
If you have power saving mode on, it goes by those settings. Check settings, my device, then scroll down to power saving mode and if it's on turn it off, that might help.
Dec 23, 2013 | Samsung Galaxy Cell Phones
I have an HP Officejet 4500 g510 - how do you turn off the power save mode? Thanks,
Called Hp, they said it is a firmware problem and they would notify me when they solved it. All I do is unplug and then plug it back in. If that don't work, make sure you have a phone line plugged in you're printer and pretend to make a phone call, this will "wake up" the printer, it will say "phone off hook". Then on the keypad of the printer push the star and pound buttons at the same time, then enter 1, 2, and 4. Scroll thru until you see "system menu" then push the OK button and find "system mode timeout" push OK then enter 1800 and push OK. Push OK again to make sure. That is the dafault setting for this printer. After doing all that you're printer will go to power save mode after 30 minutes sitting idle but it should pop right back to normal by pushing the power button once or sending a print command from you're computer. At least that's what I did and now it seems to come out of power save mode when it's supposed to....gary
Nov 08, 2010 | HP Office Equipment & Supplies
Cash register says wrong mode no matter what I do
It means you didn't finish in the other mode before you turned the key. You need to turn the key back to where you were (presumably prog mode) and finish the programming. It sounds like you have a Casio, so you would press SUBTOTAL to end programming before moving to REG mode. ------------------------------------------------------------------------------------------------------
Anyone looking for Casio cash register manuals? Try c-tech
http://the-checkout-tech.com/manuals/
May 10, 2010 | Casio Parts Cash Register PC Desktop
I think you must save the configuration before changing to reg mode.
Apr 20, 2010 | Casio Parts Cash Register PC Desktop
LG W1941S-PF keeps on going on to power saving mode
Press the menu botton continuasly 35 second,if not then replace the menu botton,if not then go o the menu and disable the power saving mode..
Jul 05, 2009 | Computers & Internet
Guys can anyone tell me how to put my phone samsung SGH-D520 to flight mode??? someone told me that i have to hold * and power it up but thats not working... i cant figure it out... thx ipodslinger :) you...
you can usually go to settings on your phone and then they will have a feature that says , air plane mode on or air plane mode off ... just search around youll find it
Jun 05, 2009 | Samsung SGH-D520 Cellular Phone
Power save mode
I had the exact same problem but it is fine now! :) And this is how you solve it .....you press the power button (single press), and a series  of options come up...if you scroll down them you will come across a 'deactive power save mode' option, click select and this should sort it out!
Hope this helps! :)
Jan 15, 2009 | Nokia N96 Smartphone
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Issues with samsung u340
on the options menu for the alarms instead of clicking to reset a single alarm you must reset all alarms at once.. worked on mine anyway.. wish you luck
Aug 02, 2007 | Samsung SCH-u340 Cellular Phone
Volume
Hit hands free button then the vol. button the once agian to change it from high to low.
Jun 13, 2007 | Innovage LCD Touch Panel Phone
Nokia 6016i Logo
123 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
