Question about Sony Playstation 3 (PS3) Console
Remote The lights on the controler keep flashing on and off, I know it is souposto do that to assign pkayer number, but it wont stop.
  • 1 more comment
  • Anonymous Nov 29, 2007
    Mine does the same thing and it doesn't need to be charged. I replaced the cable and the controller and it still doesn't work.
  • Kayton13 Dec 13, 2007
    When i plug it in the lights turn off and when i remove it it starts again
  • bogusc Dec 16, 2008
    my remote works fine when it is pluged into the ps3. It also shows it is fully charged however when I attempt to use wirelessly it only flashed and will not assign a number or do anything else.
  • 140 Answers
Connect via usb to recharge it.
Posted on Nov 28, 2007
Light wont stop flashing
Light flasher will not stop flashing.
Jan 13, 2014 | RCA Televison & Video
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Lights keep flashing
After you connect the AC adapter the display shows Set Clock for 60 seconds and all of the extension indicators flash until you assign the extension number of your unit.
Even if you do not use the intercom, assign the number otherwise all of the extension indicators will continue flashing.
Manual here
Nov 06, 2013 | Panasonic KX-TS3282 Two-line Corded Phone
Pulls to the right and stops and wont go and the control lights flash on and off
What are number of lights and colors? Check motor connections to controller. Is it freewheeling?
Mar 16, 2013 | Pride New Jazzy 600 Power Wheelchair by...
Cant pair bigben controller to ps3. Theres no where to put usb cable into it
Bigben controller and ps3
i had this problem with bigben mega pack bought with ps3 nov08
the problem is caused i find that the sony wireless controller supplied
has been already allocated as number 1 controller, this has to be changed while the bigben matches
the FIX:
boot the machine with sony controller and go into
settings\accessory settings\reassign controllers\ and re-assign the sony as number 3
(use left stick to move numbers up/down)
plug in the bigben receiver unit into a usb slot and then switch on the bigben
now the receiver light should now stop flashing and the bigben now has a single light agains number 1
go again into re-assign controllers and change the bigben to number 2
then re-assign the sony controller from number 3 to number 1
close down system
re-boot using the sony PS button (the bigben PS button does not boot PS3)
the sony should now be indicating that it is again number 1
the bigben receiver unit should have a steady red light but
the bigben will have all the lights flashing - click the PS button and they will stop
it now should only showing one light next to number 2, so is assigned as number 2 conroller
thats it
Note: I wanted to use 2 controllers for the game 'littlebigplanet'
Now if the two controllers are on, the game asks to assign a profile for the
other controller when it opens, so then you choose another user (that u have created)
Then another rag doll drops into the pod that is controlled only by the bigben (user2)
Jan 25, 2013 | Video Game Consoles & Games
My harmony 200 remote logitech needs reset it keeps blinkng
  • It's in safe mode
  • Remove a battery
  • While holding the 2 button on the number pad section of the remote, replace the battery
  • Let go of the 2 button
  • This will take it out of safe mode
  • The device buttons will stop flashing and the remote will work
Dec 06, 2012 | Logitech Harmony 550 Remote Control
HAVE SEARS/CHAMBERLAIN "91"MODEL 53615SR AND NEIGHBORS OPENER KEEPS OPENING OUR GARAGE DOOR BUT OUR OPENERS WONT OPEN HIS
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Dec 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Gigaware remote for ps3 cant connect
I can not locate a Remote For PS3 By Gigaware now if its a controller Follow these steps
Connect to PS3
1. Turn on your console and plug the receiver into the first port on the console. The RX indicator on the receiver flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. The controller’s POWER indicator lights and the 4 port indicators flash.
3. The controller connects with the receiver automatically after about 3 seconds. If successful, the RX indicator on the receiver lights.
4. Press the PS button to assign a controller number. The corresponding port indicator lights.
Manual Search
If you are unable to automatically connect, try manual adjustment.
1. Repeat steps 1 and 2 under “Connect to PS3.”
2. Press CONNECT on the receiver. The RX indicator flashes.
6
3. Press and hold SELECT and L3 (left analog stick) on the controller simultaneously for at least 3 seconds. When the RX indicator stays lit, release SELECT and L3.
n Notes:
• Repeat “Connect to PS3“ or “Manual Search“ if the connection fails again.
• If you purchase a new receiver for the controller, but have previously been using it with the supplied receiver, you will have to follow connection steps again.
Reassigning a controller number
1. Press and hold the PS button for one second. The functional screen displays. Select “Controller Settings”, then “Reassign the controller.” Press X to confirm.
2. Use the D-pad to select the number that matches the controller’s port.
3. Press X again to confirm. The corresponding port indicator lights up.
7
Connect to PC
1. Plug the recevier into a PC’s USB port. The receiver’s RX indicator flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. If connection is successful, the RX indicator on the receiver lights and the 4 port indicators on the controller turn off.
Test the controller
1. Open the control panel on your PC, and double-click “Game Controllers.” Then click “Properties“ and the testing screen appears.
2. Press the buttons of the controller. After testing, press OK to exit. You are now ready to play games.
Troubleshooting
If the controller stops working at any time, or will not connect to PS3 or PC, follow “Manual Search“ steps on pages 5-6.
Dec 14, 2009 | Video Game Consoles & Games
Cant connect a big ben interactive controller to a playstation 3
bigben controller and ps3
the FIX:
close down system
thats it
Aug 19, 2008 | Video Game Consoles & Games
Just changed batteries in universal remote don't know the code to reprogram the remote the inside says it's an rcr3273 with the numbers of r55lb5711p
Make sure the device is on. Hold down the tv (or whichever device your trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly letting it flash until the device turns off. Then press the stop button...and it is programmed.
Aug 19, 2008 | RCA Universal Remote Control
Sony Playstation 3 (PS3) Console Logo
54 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
john o grady
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
