TV CODE I was hoping to ge the TV code for a Dell W1700 so I can programmy Bell 4100 remote. Or a universial code so I can turn the TV on/offand adjust the volume. Thanks Peter
  • 179 Answers
Most universal remotes have a code serch feature, you should look in the book or online to see how to set it
Posted on Nov 28, 2007
SOURCE:
I have a ge universial remote i need the code fora dynex flatscreen tv dvd combo
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device Button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed, If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below. Codes for brands are located at the bottom of this link. http://www.directutor.com/content/ge-universal-remote-instructions
GE Universal Remote Codes and Instructions direcTutor
Nov 15, 2016 | GE Televison & Video
I Need the remote code for universial remote to operate my tv.
Remote codes are part of the universal remote, not the TV. Try the Sylvania codes in the manual with the remote. If the code is not there, the REMOTE does not have the instructions to run the TV.
Mar 21, 2010 | Sylvania 6420FB 20" TV
I have a rca universial remove but it will not
some universal remote will not work with another brand of tv,your best bet is buy the samsung remote.
Jul 17, 2009 | Televison & Video
Need to know how to program rca universial remote to sanyo 27inch
First off. What kind of RCA remote. and second 1.Turn on the TV 2. Press and hold the TV button 3. Enter the 4 digit code *1004,1048,1049,1050,1080,1107,1108,1162,1169,1180
4. Press the on off button (may need to press twice) 5. if nothing works try entering another code.
Note: your remote may only need a 3 number code. but most require 4
Mar 10, 2009 | Sanyo DS27510 27" TV
Programm bell expressvu 4100 remote control
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Mar 09, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Jan 27, 2009 | Jensen 143307 Remote Control
Dell W1700 is locked up
You need to go to the dell support site and download the Manual for that tv it tells you how to unlock that unit.
Jun 13, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Black Screen on W1700 LCD TV
As i said early ther should be an problem with your power card or ram...please upgrade it...
Dec 31, 2007 | AOC LM729 17" LCD Monitor
Don't have codes
ge codes for mad catz universal remote: 029, 031, 007, 040, 027
instructions
1) Press the "TV" mode button
2) Press and release the "SET" button (You may need to use a paperclip or small item to do this.) - The controller will light-up GREEN
3) Press the first number of the TV code - the controller will illuminate RED
4) Press the second number of the TV code - the controller will illuminate AMBER
5) Press the third number of the TV code - the controller will semi-illuminate
6) lf the first code you try does not work, try the others
hope this helps,
trin
Nov 17, 2007 | Televison & Video
Televison & Video Logo
302 people viewed this question
Top Televison & Video Experts
Ekse
