Question about Dual XDMR7710 CD Player
Dual XDMR7710 my dual XDMR7710 faceplate wont come off i have already removed two screws like i was suppose to and still cant figure it out
  • nascarfan481 Jun 04, 2008
    I have the same problem. I can't remove the faceplate, and I push that button underneath it.
Are you sure you're pulling on the click button just behind the middle underside of the moving faceplate?
Posted on Jan 17, 2008
How do you take off he faceplate of a DUAL XDMA7650 CAR RADIO?
Two small screws hold the faceplates on a lot of the Dual drop down units Open the drop down face and remove the screws. Apply side ways pressure and slightly up from one side of Player. It should release
Jun 11, 2014 | Dual XDMR-7700 CD Player
Can't remove my faceplate
Here is a link to the owner's manual for the stereo, it should have the information you are looking for:
May 21, 2010 | Dual XDMR7710 CD Player
How do I take the ice and water dispenser faceplate off? The shute that allows the ice to come out of the freezer is off the track. I cant figure out how to take the front faceplate off so i can get better...
usually a couple of slots in the bottom of the faceplate. gently insert screwdriver and pry bottom loose. push upward to remove rest of faceplate.
Jan 03, 2010 | Whirlpool Refrigerators
The dual xdmr7710 wont fit in my 2001 alero coupe, is there anything i can do? crutchfield says it wont fit but i wonder if there is something i can get to make it fit?
Hello raptor_bot,
The problem is that the dash opening in your Alero is only 6 3/8" in depth and the XDMR7710 is 7X7X2, which means that unless you cut into the vehicle firewall to make some room, 5/8" of the receiver will need to stick out the front of the dash.
Why not select a receiver that fits?
Hope this helps.
Sep 10, 2009 | Dual XDMR7710 CD Player
2 discs stuck in console
WOW!!! I am so sorry that this happened. Nintendo products are really hard to open. If you cant wedge the game out with a small screwdriver, dont worry about the game, here are the directions on opening it. Just copy and paste to word so you can see the whole thing easily.
How to open your Wii Console Step by Step Instructions
To disassemble:
  1. Flip the device upside down and remove the small silver Phillips screw. Once out, remove the battery tray from the console.
  2. Next remove the rubber foot directly above this battery tray. Also remove the three square white stickers from the bottom of the Wii. The rubber foot and the sticker are covering hidden screws. Figure 3 provides a shot of where these screws are located. NOTE
    Hiding screws under stickers and rubber pads is a common method used by electronics manufactures to help increase the aesthetics of their devices, as well as prevent people from easily locating screws and taking apart their products.
  3. Unscrew the two Triwing screws and three Phillips screws from the bottom of the Wii.
Figure 3 - Bottom Screws
  1. Flip the Wii over onto its right side. Locate and remove the two rear rubber feet and the two rectangle stickers near the faceplate.
  2. Remove the two silver Triwing screws in the holes and remove the two black Triwing screws on the faceplate (Figure 4).
Figure 4 - Left side screw locations
  1. Flip the Wii upright and carefully remove the two socket covers. They come right out with a little wiggling.
  2. Remove the three black Phillips screws from the black plate (Figure 5). Note the one closest to the faceplate is the longest and will need to go back into that hole when putting the Wii back together.
Figure 5 - Top black plate screw locations
  1. With the screws removed, carefully pull off the faceplate of the front of the Wii. You will need to disconnect the red/black wire plug from the Wii to remove the faceplate completely. Figure 6 shows what is hiding under the faceplate.
wiifig06.jpg Figure 6 - Under the Wii faceplate
  1. Remove black plate from memory/controller socket area.
Remove two silver Phillips and two silver Triwing screws from memory/controller socket area (Figure 7). wiifig07.jpg Figure 7 - Topside screw locations
Lay the Wii on left side (with the ATI and Nintendo logo facing you) and slowly work the right side cover of the console off the device.
This will take a little bit of force. If something appears to be stuck, double check to ensure you removed all the screws.
Locate and remove four screws holding DVD reader in place. Two are located in plain site in the middle of the unit. Two are located near the front of the Wii inside the DVD unit (Figure 8). wiifig08.jpg Figure 8 - The insides of the Wii
Slowly tilt the DVD player upward toward top of Wii. There are two wires that need to be disconnected before you can safely remove the DVD unit. One is a plug type of connector that only requires a little tug. The other is a circuit strip connector that requires you to lift the brown catch, which will release the pressure holding the strip in place (Figure 9). Do not break this!
May 11, 2009 | Nintendo Wii Console
Need a new wiring harness for my Dual XDMR7710
Look in your local phone book yellow pages under stereos for a local (not big name) stereo installation store (there will be one) and go will thank me!
Feb 22, 2009 | Dual XDMR7710 CD Player
How do i use this thing
Yes it should screw on and the sanding pads should either be sticky or velcro
Oct 02, 2008 | Ingersoll Rand Ingersollrand Dual Action...
Duak XDMR7710 The radio gets power but it wont turn on
The wires may have come loose from your harness or from your tapped locations. Re-check everything you did. Use this guide to see where you may have gone wrong.
Jun 04, 2008 | Dual XDMR7710 CD Player
Detaching faceplate on dual stereo XD 7500
Got to the following lik for your manual: Refrence page 6 for instructions. With the unit off, press open to allow the front panel to slide down. Genetly squeeze the release tab located on the bottom center underside and pull faceplate down and away from unit to remove. To install insert left side faceplate first then push right side to secure. Hope this Helps L8R
Sep 18, 2007 | Dual XD-7500 CD Player
Samsung SGH-P777 faceplate removal
hi this is ram i have a cell model- sgh-p777 BUT sim is not workaing massage is wrong cord how to do
Aug 07, 2007 | Samsung SGH-p777
Dual XDMR7710 CD Player Logo
305 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
