Air Purifiers
Problem for Air Purifiers
Generic problem for all Air Purifiers
Is the light on the control panel sup...
By ladydeb543 on Aug 09, 2009
is the light on the control panel supposed to stay on all the time
It didn't seem the EAC-14 was working properly. When I looked at the unit, the green light was not on. I pulled this off, took out filters and cleaned, replaced everything. The green light did not come back on steady after I tuned the unit back on. Is this normal. I thought I saw the light on all the time when it had been installed
Solution #1
posted on Aug 09, 2009
Not Rated)
hvac50
Rank: Guru
Rating: 88%, 30 votes
the electronic cleaner can not get wet. if you put the unit back on without drying the filter paks you will short the control pak out.
Was this helpful?
Yes
No
Popular Solutions for Air Purifiers
Questions and Unsolved Problems for Air Purifiers
Answer
i have a Flair 120v dual plate purifier. the fan blows and the little amber light is on but its not... (More)
Answer
Air cleaner shuts down after 3 to 4 minutes of run time. When I try to restart, it will shut down... (More)
Answer
I have three but now only one 1 can feel any air movement.The other two the lights are on but I do... (More)
Answer
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Purifiers:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2530
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
