Question about Panasonic NN-P994SF Microwave Oven
IT CONTINUES TO RUN AFTER DOOR IS OPENED
PLEASE HELP, IS THIS NORMAL FOR THIS MODEL, AND OR COULD i HAVE IT IN demo MODE, OR STAND TIME MODE, AND IS IT DANGEROUS
  • sagon1 Nov 28, 2007
    THIS IS REFERRING TO THE PANASONIC NN-P994SF MODEL
  • Panasonic Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or possibly a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
Demo mode on..how do I get it off
What is the make and model?
Jul 17, 2013 | Microwave Ovens
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
Stuck on demo mode. how do i get it back to working
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/NNC994S.PDF
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 24 of the manual for instructions on how to deactivate the DEMO MODE.
Basically, if your Panasonic microwave display shows DEMO MODE, then just press the CLOCK button on the control panel 3 times in a row.
The display should then go blank indicating that it has successfully returned to normal cooking mode and can be operated as usual.
A few models require you to push the CLOCK button 4 times to clear the DEMO mode, so try that as well if the above instructions do not work for you.
I truly hope that was helpful to you Monique.
Good luck and take care.
Joe.
Dec 04, 2011 | Panasonic NN-C994S Convection/Microwave...
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
My lg fridge is giving me an error code of FF what is this mean
Your LG refrig is in Demo Mode.
1.- disconnect power supply and reconnect
If the error continue
1.- Open the door of refrig.
2.- Press button "Refrigerat" while press "Ice P" button 15 seconds
If the error continue try again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | LG Microwave Ovens
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Stuck in demo mode after power outage - any ideas on how to get it out? model is JVM2070
Talked to GE Help Line (1-800-626-2005) and found out the magic key combination for this microwave. Plug in after being unplugged for at least 30 sec. and then press Help plus Boost at same time for 3-4 seconds (until it beeps). The microwave will now be in normal mode (I assume you do this to put it in demo mode as well).
Sep 13, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 13, 2008 | Microwave Ovens
Demo Mode
Unplug the microwave for at least 3 minutes, then plug it back in, and BEFORE SETTING THE CLOCK, press and hold power level and start for three seconds. This should flash "demo mode off". Set the clock as normal. Enjoy!
Mar 31, 2008 | GE Advantium SCA2000B Microwave Oven
Microwave Ovens Logo
63 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
