Question about Kenmore 74832 Gas Dryer
My clothes smell burnt
After running a full drying cycle my clothes smell burnt. I called Sears and they want 200 dollars on a one year warrenty on a 3 year old dryer. Any suggestions?
  • Anonymous Nov 11, 2008
    I have had the same problem after dry walling the basement. How long does this persist?
  • Anonymous Apr 01, 2014
    My husband sweats heavy and the latex mattress smells and there is mold growing. twice he used baking soda dry. Wet the surface with vinegar (not soak) and let it air dry, but he took an iron and ironed the latex mattress to quickly dry it and now there is a burnt stench. I took over, for three days I aired out the part of the mattress that is affected, used vinegar, baking soda, organic lemon scent odor destroyer (each time the mattress dries), it just left the mattress with a heavy sickening smell. I also used peroxide and the smell is faint but still there. I get sinus headaches and stuffy nose for days on end from the perfume, What can I use that is unscented. THNX.
If you have done any recent painting or drywall work, oftentimes the dryer will breathe these fumes and it will affect the smell of your clothes. (Just had the same problem) Maybe let the area air out and see if that corrects your problem
Posted on Dec 14, 2007
SOURCE:
Clothes smell burnt after drying
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 10, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Tip
You are the man!!! I was just about to call Sears when I decided to look around...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Oct 21, 2009 | Kenmore Elite 45986 Front Load Washer
After I dry my clothes, I smell this dead animal smell. Thought it might be a dead animal, but could it be the ring around the drum that is burnt? My clothes now dry smell stinky. We took it all apart...
thats the mold and mildew on the bellow that you are smelling. thoroughly clean the bellow. i also suggest that you purchase a tablet called affresh. this will help to remove that smell. if your machine does not have a self clean cycle then just put the tablet in and do a regular wash. if you machine has a clean cycle, just put tablet in and set on clean cycle. I also recommend that after each load you thoroughly wipe off the bellow and leave the door open for about 30 minutes so that machine can air out.
Feb 05, 2011 | Dryers
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My dryer makes my clothes stink
You NEED to have a professional vent company clean your dryer out! PLEASE don't run your dryer when you're alseep or not at home due to a fire hazard! It sounds like the dryer is full of lint that's buring and make sure you clean your lint filter EVERY time you dry a load for safety's sake and energy efficiency.
Aug 14, 2009 | Dryers
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
Clean LED Light does not come on
no its usely the touch panel if everthing working dont bother with it about a 200 dollar part
Aug 26, 2007 | Kenmore Elite 45986 Front Load Washer
Drying cycle runs but does not dry clothes
more than likely that your thermostats have blown if you could smell the heater element getting hot then this will be the case m8
Nov 23, 2006 | Hotpoint Aquarius WD640 Front Load...
Kenmore 74832 Gas Dryer Logo
964 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
