Question about GE Kitchen Ranges
Ge wiring diagram
Can anyone tell me where i can obtain a ge diagram for a older range model jcp67_01_wh
4 Suggested Answers
  • 83 Answers
SOURCE: wiring diagram
try the whirlpool or kitchen-aid web sites I looked up your model # at 1st source parts and that model is not there
Posted on Dec 07, 2007
  • 160 Answers
or go here
the ge site may have what you need, but some of the others may be more productive.
Posted on Dec 05, 2008
  • 1214 Answers
SOURCE: older ge spacemaker range, temps wont boil water
Check your breakers to the oven. It sounds like one of the two of them have tripped and you are only getting 120 VAC.
Do you have a volt-ohm meter, and know how to use it?
Posted on Dec 18, 2009
Testimonial: "good thinking! now where are breakers? need to pull out stove?"
  • 9472 Answers
SOURCE: Re: wiring diagram GE monogram range Model
If the bake and broil elements will work when you set the control to bake or broil then the likely failure is either the oven control board or a failed door lock switch. Generally speaking if your range has a digital display it should indicate if the door is not closed/locking and or an error/fault code.
The Electronic Range Control (ERC) must detect a closed oven door before it will start a clean cycle and lock the door. The door lock mechanism must close a lock switch once the door has locked before the ERC will start the clean cycle.
You can try resetting the range by disconnecting it from the outlet or switch off the main circuit breaker of the home for 20-30 minutes then restoring the power. If the reset doesn't work, you may have a faulty control board or door lock assembly.
Posted on Feb 07, 2011
0 characters
1 Points
What is the color code for a 3 coil GE burner
color code? as in the wiring colors? the tech sheet should have a diagram on it...
May 20, 2016 | GE Kitchen Ranges
Wiring diagram for ge 3 coil range burner
Go to the back of the range. The wiring diagram with be on the back, or inside the top console. They hide them there for service engineers. Washing machine diagrams are in the bottom or in the top console, Fridges are behind the back of the freezer to the right of the evaporator coils.
Your colour coding is probably the same on all burners. There is normally only two wires.
May 16, 2016 | GE Kitchen Ranges
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
I need the wire diagram for a GE range M# JB680SPSS
  1. Type in this Model # JB680SPSS "Only" on the website:
  2. This is what they have to offer you free to download on this website. (Manual's)
  3. JB680SPSS
    GE® 30" Free-Standing Electric Convection Range
    Quick_Specs, Use_and_Care_Manual, Installation_Instructions
Hope this helps you out. wvrain2006 :)
Sep 29, 2010 | GE JB680SPSS Stainless Steel Electric...
I have an older model GE Profile Spectra electric oven/range. It is beeping, and displays "FO" next to the clock. What does this mean, and how can it be fixed? Thanks!
This indicates either a stuck button if not the ERC needs to be replaced. The ERC is the Electronic Range Control.To check for a stuck button press each button one at a time and see if you can feel the slight click. If you have a stuck button you will need to replace the keypad membrane. Both are easy to replace. You can get diagrams and illustrations at by entering your model #. All parts come with installation instructions.
Apr 11, 2010 | GE Profile Spectra JBP48 Electric Kitchen...
Trying to identify an old GE electric range and find service manu
That is definitely an oldie, but a good one. I always pull each burner, remove the clips off the ceramic insulator, and replace one wire at a time. If you look at each burner control, they should all be the same ie. #1 is the same on each. There are usually only 3 wires on the small burners, and 4 wires on some of the dual coil larger burners. Also, on the back panel, there is supposed to be a wiring diagram glued to it. I may still have some parts for it if you need any.
Jan 09, 2010 | GE Kitchen Ranges
Stove burners will not light
I went directly to GE's website and found the diagrams for my stove with the parts listed. Thats what I needed !
Thank you,
Jun 29, 2009 | GE Kitchen Ranges
Ge Profile model jgb900 has error codes & oven doesn't work
Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Mar 06, 2009 | GE Profile JGB900 Gas Kitchen Range
Need wiring schematic for Hotpoint Range Model RB757H1WW
I contacted GE, for the wiring diagram and they are sending them to me,
Thanks for your reply
Jul 31, 2008 | Hotpoint RB757 Electric Kitchen Range
Kitchen Ranges Logo
777 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
