Question about Compaq Armada E500 Notebook
I cant install windows in my computer
I try to install windows 98, 2000 and xp in the computer after an error on the HD but when left 18 minutes to finish the pc sudenly freeze and dont react before to frozen, the monitor turn off and later turn on what hapend in a few times whit my pc?
  • chacmol2099 Nov 29, 2007
    Yes, i try whit 2 cds and nothing, in the begining the computer has windows XP but i cant acces to the operative system, i try to install windows 98 & 98 SE and was the same, with windows 2000 hapened the same thing but during the instalation the screen was flashing 3 or 4 times an after format dont install the program just freeze remaining 15 minutes to end what i can i do?
  • Anonymous Jul 07, 2008
    how do i delete windows 95 from my pc and install windows 98. What are detailed procedures to follow.
  • 51 Answers
Have you tried another installation CD?
Have you performed a HD format with a Windows 98 boot disk?
Posted on Nov 28, 2007
  • Mrunal Mody Nov 29, 2007
    It looks like there might be bad sectors on the hard drive, causing it to freeze during install.
    With a Windows 98 bootable disk, boot to the command prompt. At the prompt, enter a command. Upon proceeding, answer Y for large hard disk support and confirm.
    Select 4 to delete active partitions. Delete the partition and create a new partition. You can select FAT as the primary type. Let the fdisk utility perform a format of the entire hard disk. Then attempt to install the OS again.
    If it fails again, I recommend you run a diagnostic on the hard drive to check it's integrity.
    Do you know the manufacturer of the hard drive?
I don't know if it is a problem but when i plug in a mouse to my computer it doesn't detect it at all i don't know if something changed in the BIOS it has windows 98,2000 i had windows xp on it but it...
Dear macrocks22 :
If you are using a PS2 connection for your keyboard and mouse you will need to reboot windows for it to see them. Its just random how it sees them or not.
Any version of windows earlier than windows XP with second edition update will have problems with anything related to USB. Its just hit and a miss if you are trying to use USB connections with windows earlier than XP with SP2.
Hope it helps, if it does don't forget to give the thumbs up.
Feb 07, 2011 | Intel Motherboard
My os is win vista 32 bit and i cant run 18 wheels of steel. the error said 18 WoS Haulin. what should i do?
change ur os to xp then run this game and i m sure the game will run and remember to install latest graphic driver and directx.
Mar 30, 2010 | ValuSoft Hard Truck: 18 Wheels of Steel...
Hello I have a Problem for Dell PowerEdge 400sc and cant get windows xp installed, I am able to reformat the HD but cant get xp to load and at one point during the installation it says it cant install...
try another windows xp disk or burn another copy of the disk you have. it's also possible that there's a problem with the optical drive that you're using.
Mar 15, 2010 | Dell PowerEdge 400SC Server
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Dec 21, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
I am having problems with reinstalling my audio driver, was corrupted and I had to uninstall it, now when I have tried to reinstall from toshiba website the message " This system does not support the...
DATE: CATEGORY: TITLE: 01-30-2007 Driver
Sound SigmaTel HD Audio Driver for Windows Vista (v6.10.0.5324; 01-30-2007; 8M)
02-07-2006 Driver
Sound SigmaTel HD Audio Driver for Windows XP (v5.10.4889.0; 01-18-2006; 10M)
02-24-2005 Sound
Toshiba Utility Toshiba Speech System for Windows XP (v1.00.2511; 02-24-2005; 19M)
02-07-2006 Driver
02-24-2005 Sound
Here's the link to your drivers... Notice the first and second choices are different... one is for for xp... Pick yours and also download/install the speech system driver (the 3rd choice)
Dec 03, 2009 | Toshiba Qosmio G35-AV600 Notebook
I cant install windows xp because of... i dont know!
Here is what you should do, go to a computer store and buy a 40G HD. Try installing on that. It could be the size, but most likly not. Im going to guess and say take a look at the bottom of your reinstall disk. If it has any scratches, there is your problem. NTLDR is your boot sector on you HD.
Mar 04, 2009 | Intel Motherboard
Ntldr error on ibm intellistation z pro w/ xp pro
During the XP install, you will be given the chance to set up partitions on the drive. Blow them all out. Completely. Then recreate the partition and let XP install. I expect this will solve the nt loader issue. If, however, it does not, then use the recovery approach below to get the required loader files onto your boot partition.
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "d." This letter may be different on your computer.
    copy d:\i386\ntldr c:\
    copy d:\i386\ c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Mar 04, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Failed vista uninstall
do install the vista only, coz xp could not recognize the sata hd, it gives the blue screen error, if u want to install xp otherwise, install sata divers from the supplied disk with computer.
Nov 21, 2008 | Acer Aspire 5920-6727 Notebook
Hd audio driver fail
i have intel 945 motherboard when i install audio driver i found error hd driver fail how can i resolve this problem.
Apr 09, 2008 | Intel Creative Labs Sound Blaster 16 PCI...
Aug 25, 2007 | Singer CE-200 Quantum Futura Computerized...
Compaq Armada E500 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
