Question about Toshiba 50H72 50" Rear Projection Television
Toshiba 50H72 50 in. Rear
Wavy picture, totally distorted, can only watch on pip for clear pic on one side
    President:
  • 4,402 Answers
Possibly the STK392-110 ic's? it seems like it is the vertical convergence.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 14, 2007
SOURCE:
How do i fix a 57 toshiba cinema series exhibiting a wavy distorted pic, which usually occurs after watching for 30 or 45 minutes
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 05, 2015 | Toshiba Televison & Video
Pulsating pic
there is a digtal board incased in metal right behind your input board change all the 10uf caps this should fix your problum
Apr 22, 2010 | Toshiba 42H81 42" Rear Projection...
My 57" Toshiba projection TV recently started having picture problems. The picture is distorted and wavy. The picture on the PIP screen is fine. is this a common problem and is it fixable?
First bypass the cable box and hook the tv directly to the cable to see if the problem goes away. if the problem persists you possibly have a bad input board.
Mar 13, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
My Toshiba 50H82 television takes about 30 minutes to clear up and during that process, it shakes.It becomes clear but still has wavy lines at the top of the screen which is about 6 inches.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2010 | Toshiba 50H82 50" Rear Projection...
Fuzzy/ distorted tv pic
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Dec 22, 2008 | Toshiba 57H81 57" Rear Projection...
Distorted Picture
the hyper module is defective needs to be repaired or replaced.
Aug 03, 2008 | Televison & Video
Distorted Picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
Tv has wavy lines 6" from top and sometimes from the right side a wavy line
heart ach... of having bad convergance amp ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 20, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
