Question about Sony VAIO PCG-K25 Notebook
Monitor is gray color and fuzzy.
Monitor is gray, black, fuzzy. Doesn't display anything.
any help will be appreaciated.
  • bluebells587 Nov 08, 2008
    Hi, I have a Sony VAIO K-25 laptop with Windows XP Home. Last weekend, my laptop was switched on overnight, and in the morning, the display colors on the desktop screen went bright white and fuzzy. I have tried to reduce the brightness to the minimum, and also tried to change the display settings on the Control Panel to different colors, but am not having much luck. I can barely view the icons on my taskbar, it is very bright and white. I am not sure I am describing this very well, but bottomline, it appears that the color contrast does not work anymore. Can anyo
    ne help? thanks in advance.
I turned it off for a day and back on. It's working now somehow.
Maybe the monitor got overheater or something.
Posted on Dec 09, 2007
  • 138 Answers
Can you tell us how this happened??
When you start nothing is being displayed then it might be due to your video card not working! If it gets stucked when you r working then their might be problem with your video driver!
Posted on Dec 08, 2007
SOURCE:
Does this tv need a converter box or can I just use an antenna for over the air channels???
Most likely it needs a converter box. To see for sure, just turn it on and look at the channel type.
1. Channels are displayed as decimals, such as 17.1, 17.2, 17.3, 18.1, 18.2, etc. In this case it's a digital TV which needs only an antenna. Also usually TVs like this display no signal as a blue or black screen, though sometimes they can have the fuzzy gray screen.
2. Channels are displayed only as single numbers, 1, 2, 3, 4, etc. Most likely the screen is gray and fuzzy, maybe making a loud fizzy noise, when you have no signal. It's an analog TV and you need a converter box.
Apr 30, 2018 | Televison & Video
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
My screen gets fuzzy contact need cleaning?
Try to connect laptop to extern monitor, if picture on an extern monitor OK, then You must exchange display ribon cabel.
Dec 14, 2012 | Dell Inspiron 1750 Laptop
Hi, I have a asus VW192DR lcd monitor but it cannot open properly, only mixed colors, is there any chance that i can fix it on my own? pls help.
ASUS DISPLAYS are pretty FUZZY, HARD TO REPAIR but also HD and VIVID. ASUS DISPLAYS are usually HARD SEALED from the inside. Try paying it a rest and RESTARTING . Doesn't work? , DETACH the STAND to make it easy to work. The SCREWS to OPEN an LCD MONITOR are usually near the VGA/DVI/HDMI CONNECTORS. HOPE THIS HELPS.
Sep 08, 2012 | ASUS LCD Monitor
I have an HP dv6707us laptop. The display started getting fuzzy and turning redish and would fail to display anything after a few minutes. I plugged in an external monitor and it works fine. I disassembled...
The screen replacement is defective or the part number is wrong, check the part number on the back of the original screen and compare it against the the one you replaced, it should match.
Jun 15, 2011 | HP Pavilion Dv6707us Entertainment...
Movement of my desk caused the monitor (XG-91D) to lose some of the colors. The screen only displays greens, blue, brown, gray and black tones. Readjusting the screen temporarily helped but it goes out...
Try a new cable. If any of the pins is slightly bent the monitor will not receive the correct signal to display. I would recommend a new cable even if you don'y see anything wrong with the old one.
Dec 09, 2017 | Xerox XG-91D 19" LCD Monitor
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Fuzzy, unstable display
This sounds like a high-voltage power supply problem, which would need to be diagnosed by an experienced computer or electronics technician.
Check to see if there is a small focus knob on the back. If so try turning it back and forth three or four times to "clean" it....then adjust for correct focus.
Symptoms like this can also be caused by accumulated dust inside the monitor.
Jan 15, 2008 | Sony GDM-C520K (Dark Gray, Gray) 21" CRT...
Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Jan 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Sony VAIO PCG-K25 Notebook Logo
91 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
