Question about Lanzar 2H 1000W MOSFET AMP Car Audio Amplifier
Audio bahn 1205n
My amp is a lanzar vibe 800 watt i bridged it to audiobahn 1205 n and after a few minutes it goes to protect mode
  • 155 Answers
Sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Posted on May 11, 2010
SOURCE:
How do i reset my 4000 watt lanzar vibe 286 from being in protect mode
You can only reset it by disconnecting power to it. If it is in protect you may want to check your speakers and speaker wires for shorts and/or grounds. If they check out all right you may have internal problems in the amp.
Oct 28, 2011 | Lanzar VIBE286 Car Audio Amplifier
How can i bridge all 4 channels together on my lanzar vibe 410 car audio amplifier
you cant , you can only bridge 2 channels together and what are you trying to run off the amp?
Jan 30, 2011 | Lanzar Vibe 410 Car Audio Amplifier
I have a Lanzar 4000 watt amplifier hooked up to 2 12inch MA Audio subs. When I crank my car the green power light on the amplifier comes on, but after a second or two it changes to protection mode. I have...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to get an old school Opti Drive. .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-4000-watt-amplifier-hooked-up-2-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Jan 29, 2011 | Lanzar VIBE286 Car Audio Amplifier
I have a dub2502 amp with the red protection light on and will not go off. The amp is a 1100 watt peak amp @ 4 ohms and my sub is an Audiobahn 1100 watt peak, 4 ohm. wired perfectly. so how do I fix the...
The unit will need to be repaired by a technician. Most likely you have a bad transistor that is causing the protect mode to turn on. The only way to get the protect mode to turn off is to remove the bad part.
May 04, 2010 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
Lanzar amp 1000 watt stays on protect mode
Hello snow11879,
I haven't been able to locate any support information online about your product, other than the email contact for support questions:
[email protected]
If the amp stays in protect mode all of the time, I would suspect a short in the speaker wiring or speaker(s) voice coil(s), or perhaps a faulty ground. If it plays for a short period of time and then goes into protect mode, it is most likely overheating. First check all of the wiring. Test your speakers on a known good amp and make sure there are no places in your wiring where the insulation may have been damaged, causing an intermittent problem.
Many owners have reported that this particular amp has a tendency to overheat. Also, when run in bridged mode, the speaker impedance needs to be at least 4 ohms. It will overheat if the impedance is below 4 ohms.
Hope this helps.
Apr 18, 2009 | Lanzar VIBE266 Car Audio Amplifier
Audio bahn a 1800
If it has cooled down and still goes into protect mode, it likely has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 23, 2008 | AudioBahn A8001DT Car Audio Amplifier
Protection light grief
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Vibe is mediocre. Time to invest in an old school Lanzar Opti Drive amp. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-grief-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jun 11, 2008 | Lanzar VIBE266 Car Audio Amplifier
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
My amp wont go past protect mode
Disconnect all speaker wires and signal cables from the amp. If it powers up (no protect light), the wiring needs to be checked. If it still shuts down (goes into protect), the amp likely has blown output transistors.
Dec 01, 2006 | Lanzar Vibe 218 Car Audio Amplifier
Car Audio & Video Logo
139 people viewed this question
Top Lanzar Car Audio & Video Experts
Mike Duncan
Mike Duncan
Joe Alexander
Joe Alexander
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
