Question about RCA F32665 32" TV
BROKE PART OFF TV-RCA F32665
I WAS MOVING MY TV WHEN I RIPPED THE PART THE CABLE PLUGS INTO OFF OF THE BACK OF THE TV. I WENT TO RADIO SHACK AND BOUGHT A COAX F CONNECTOR. I CAN'T FIGURE OUT HOW TO PUT IT ON. I DON'T KNOW MUCH OF ANYTHING ABOUT TV'S. SHOULD I JUST CALL A REPAIR MAN?
  • LIZZOE Nov 28, 2007
    -----BMW RIDER
    the number after F32665 is YX5
    the serial number is 009433214 --- I didnt know if that will help narrow down the search or not , i figured i'd throw it in.
    Thanx
    Novelist:
    Champion:
  • 232 Answers
Hi, some of those units have whats called a "RF cable" running from the back of the set to the tuner, and some are directly spot welded to the tuner, you need to remove the back from your set and see if yours is a short cable to the tuner, otherwise you have to replace the whole tuner, check the back of your set and you`ll see on a sticker the complete model number, (few numbers or letters after F32665) this is referred to as the service model number and I can look up exactly what you need to change
Posted on Nov 28, 2007
  • Larry Eastman
    Larry Eastman Nov 29, 2007
    Your tuner comes up as "non replaceable tuner" which means it must be an "on-board tuner" which means it`s part of the main module. It does list an rf cable assembly which is what I believe you need, part number is 247714 which you should be able to get from any tv shop locally and install yourself. I would take the back off the set and verify this info but according to the parts listings it`s what you need, good luck
SOURCE:
How do I connect a DVDs player to an older model television
you can buy a little box at Walmart Bestbuy or radio shack. you just plug i the RCA cable into it and then run the coax cable to your TV and plug it in to ac wall outlet. some handle more than one RCA plugs so you can ad tings like game systems.
Nov 29, 2014 | Televison & Video
The coaxial cable antenna broke on my RCA tv
The part is called a Female Belling-Lee Socket. Radio Shack, or anywhere that sells antennas, CB radios, repairs TV sets, should have one. Soldering it in, is another matter. Be careful.
Feb 04, 2010 | RCA Scenium D40W20 40" Rear Projection...
Antenna/Cable Connector partially ripped... Hi, everybody. Does anyone know how to fix a ripped antenna/cable connection? Thanks for the help. My TV Model is a Daewoo DTQ-13P3FC 13" TV for more details....
The cheapest way i can think of is open the tv and solder the ripped peice back on. That should work. If not you can go to radio shack and buy a new peice for it and install it by soldering the connections back on. Hope I could help.
Wayne
Jun 26, 2009 | Daewoo DTQ-13P3FC 13" TV
Cable connection broke on back of tv
YOu will need a box that will convert your coaxial signal (cable) into a another using either Composite (RCA wires) or component (Yr,Yb, Yg) outputs. Your local radio shack should be able to accommodate you
Apr 01, 2009 | Philips 32PF9986 32 in. HDTV-Ready LCD...
Main cable connector broke off back of TV
Maybe so. Sometimes the connector is fed by an RCA connector which just plugs in inside the TV and sometimes it needs a little solder work. Sometimes you have to solder on the circuit board and if it's a multi-layer board you want an expert to do it but from the manual it doesn't look like that is the case with your TV.
I'm pretty sure Radio Shack stocks such connectors with maybe a little hardware to get the fit right.
Dec 17, 2008 | Televison & Video
Broken cable tv port on Mitsubishi CS-27209
Yes but repair shop charge alot
for this , and it's easy repair .
You can buy some solder , 40 watt soldering iron , Male coax plug from Radio Shack and
resolder two connections and save 100.00
RADIO SHACK HAS THEM
IT ,
Dec 16, 2008 | Mitsubishi CS-27209 27" TV
Cable antena ready input repair
Purchase replacement at radio shack, disassemble the tuner, and solder the replacement in. It is not a screw in.
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv F32665
Try other inputs such as rca and svideo.
Aug 18, 2008 | RCA F32665 32" TV
My TV is fine...problem happen when I was moving today,not sure what its called but its the silver projection located on the back of the TV is which you connect the cable on the wall too...it broke...
Hook the cable up to the VCR or if you don't buy a RF converter from radio shack or electronics store which will have a coax connector on it with component and Svideo to send to the TV. Select the connection (Component or Svideo) in the TV menu. If you only have the coax connector on the back of the TV without any other connection, you will need to get that tuner board replaced.
Aug 18, 2008 | Televison & Video
RCA F32665 Shows only gray screen, sound works.
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Jun 14, 2007 | RCA F32665 32" TV
RCA F32665 32" TV Logo
98 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
