Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
The "cancel" button for the upper section of my maytag gemini gas range no longer works. I used it yesterday and in order to get the oven to turn off, I had to unplug the range from the wall. Help!
  • chrisandmike Oct 23, 2009
    Thanks! I figured that out too and now it works great again. I have banned my husband from touching it though as he tends to stab the buttons too hard believing that using brute force is the way to fix something whereas we know that it's better to use brains than brawn!
    New Friend:
Mine was doing the same thing. It was a stuck button under the touch membrane. If you are slightly mechanical you can fix it yourself, by first unpluging the oven from electrical power. Remove the upper panel, by taking 2 screws in back off. Also 2 screws on bottom. You can now tilt the upper control panel down to get at the controller itself. I removed it and unstuck the button. Works fine now.
Posted on Oct 23, 2009
SOURCE:
Gemini Electric Range MER6772BAS- lower oven upper heating coil doesn't work. Everything else works fine.
Replace upper coil by removing,and take it to applance parts dept and have them order a new coil(check coil by using a test meter look for low ohms.
Jul 17, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Oven lights will not turn off, Maytag gas double oven range Prec. touch 750
Hello bohlke75,
Welcome
You said, After cooking in the upper oven today, my wife noticed that both oven lights were on. I tried to turn them off but the oven light button just beeps when activated. I individually tried the plunger switches on both doors but that did not work either. You also unplugged the stove with the hope it would cancel the lights but they came right back on when i plugged it back in. You assume it is something in the touch pad since both lower and upper lights are affected.
Did you leave the plug out for 5 minutes or just do it quickly?
if it only happens on one door then the plunger switch is bad!
if it's both doors then you have a button or control problem. Service can give you a true diagnoses with out the cost of swapping parts randomly!
If it was the plunger you may have been able to get away with a do it your self repair!
Let me know how you do
Thank You,
Huuum
Please remember to leave a rating!
Sep 09, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag Gemini Dual Oven MER6772BCA
sounds like the broil elemnt in the upper oven is shorting itself out part number 74004106, probly 45 bucks. leave the circuit off adn replace it... the wire(s) leading to it are always live.theres a few screws across the top of the cavity holding it up
Apr 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini gas stove
on the oval window of my gas stove, maytag it says 5 Ab my oven won't work because of this
Oct 29, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
369 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
