Question about Siemens SpeedStream 4200 (13A4200001) Bridge
I hate my server and their little black box toooooo!
Im so fed up every night we try to get online....can open the first page no problem but if we try to open a window inside of that can go 2 of my little green lights go out and poof it acts as if im offline. so i go to sometimes it says disconect...most times it says not trained and i have to put in our password etc ...once it shows im online i try another site again...poof lights out thats all folks. Ive contacted my server they arent very helpful....I want my cable internet service back WAAAAAAAAAAAA...woe is me...SOS HELP fast or im breaking the little crock sucker.
  • 99 Answers
Re: I hate my server and their little black box toooooo!
If all of the lights go out or the DSL light stars blinking with no other light on then that usually indicates the modem lost sync. That is usually caused by noise on the DSL line. If the DSL line and phone line are on the same cables then you should have filters that need to be installed on every device connected to the phone lines except for the DSL modem. If that has already been done then you would need to contact you service provider as the issue is most likely going to be a problem with the phone lines in your house or their lines outside your house. Your ISP will be able to test your DSL line to get an idea of where the problem is. It is also possible that this is an issue with your modem and it needs to be replaced. Ig you are leasing the modem then once again you will need to speak with your ISP about it. If you bought the modem then you would need to contact Seimens about it if the modem is the problem.
Posted on Jan 03, 2009
0 characters
3 Points
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Im trying to install a DAP-1522 as a bridge with my Linksys WRT610N V2. How do you do it. I find DLINK very hard to set up
Hi Friend,
Please follow the steps to install the DAP-1522
1) First connect your computer to the linksys router with a wire,dont connect the DAP. Now if u have windows XP please try this
2) Now ,click the start menu>run>type cmd and hit enter
3) In the black window,where the cursor is blinking type ipconfig/all and hit enter
4) Out of the bunch of information please note down the ip address and the default gateway
5) if the default gateway is
6) disconnect the computer from the computer and connect the DAP to the computer directly
7) click start menu>control panel>to your left you will see "switch to classic view",please click that>double click the icon named network connections
8) Inside network connection you will see an icon named Local Area Network connection,right click and click properties
9) under the general tab you will see Internet protocol(TCP/IP),select that and click properties
10) In the new message bos you will see 4 radio buttons,select the second one from the top
11) in the Ip address box type
12) Click ok and then close
13) now open the internet explorer page and delete evrything from the address bar and type the number
14) You will get the page of your DAP
15) set the fixed ip of the 1522 to,DHCP should be disabled.
16) Make sure that you have set the wireless password so that no other people can mess up with your network
170Save the settings.Once done unplug the bridge and enjoy working wireless.
Warm regards
Chiranjeet Mitra
Oct 08, 2009 | Network Bridges
How do I get the ip address's that come into my 4200 speedstream
connect your router to computer with ethernet cable.
Then go to start menu then type in run 'ipconfig /all"
you find ip adreses sub net and GATEWAY.
GATEWAY ip is your router ip.
Let me know if you need more assistanse.
Aug 27, 2009 | Siemens SpeedStream 4200 (13A4200001)...
I have problem with my Internet connection
yeah i had that problem 2 days ago go to and type in your user name and password click save settings and if you see the connect button press connect and if that doesn't work try getting a ball point pen and press down on the reset button for 5 seconds and it will have a flashing light on the last thing and that means it's powering up try it again until 3 solid lights come on and the last thing is flashing
May 22, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Senao 3220 - access configuration info
I do not know what you have for a DHCP server but some DHCP servers will show you what devices have been given IP addresses which you can use that information to find what address it is at now. Other than that you can use the guess and check method just going through IP addresses until the page comes up, you can use network mapping software to scan your network to find it or you can reset the access point to factory defaults where it will have the default IP address that you can then connect to and re configure it the way you want it.
Jul 06, 2008 | Network Bridges
I got ur question, try following steps and i hope it may solve your problem soon and also reply back to me if it solves the problem:
1. Hard Reset the Modem(on back side of modem or underneath you will find the small hole that says reset you need to press and hold that button as soon power light on the modem flashes release the reset button)
2. Go to control panel then go to network connection> on leftside click on create a new connection>click on next>select the first option Connect to Internet>next>select second option set up my connection manually>next>select second option connect to broadband connection that requires user name and password>next> typpe your internet user id and password and confirm the password>next>click on Finish..
3. You will get a new window with your connection name just click on connect at the bottom of that window, you will get connected OR you ill get some error if you wre not be able to connect, note the error if you get that there.
4. open internet explorer then browse the internet if you are connected....
5. If You face any problem reply back to me here with your ip address,dns server,default gateway so we can try to put manuall address on your modem.
6.Other thing that you can try is cick on start>> go to Run box>> Type>netsh dump>> click on ok>> wait for 2 minutes th reboot your computer and try to connect through connection that you would create in network connection.........
reply back to me pls........
Jun 02, 2008 | Siemens SpeedStream 4200 (13A4200001)...
D-link di-604
I have no success disabling the DHCP server. For me at lease, this will not work
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Not capable of recording
A tuner converts broadcast (including cable) signals to composite video that the TV uses. Now that the broadcasters are going digital, equipment sans tuners like yours are on the market. You can either return the unit for the older style or you can buy a converter box for your cable. The Fed Gov is going to be offering 2 $40 vouchers per household to help you with the change over but it hasn't commenced yet.
Dec 31, 2007 | Network Bridges
Siemens Speedstream 4200 Driver
Visit this link On the left side under the heading Speedstream 4200 download and isntall both the drivers and firmware.
Once you've installed the firmware open iexplorer and goto . Type in an admin password and save settings. Type in your username and password ( provided by your isp ) press save again and then press connect. you should be in business.
Nov 09, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
294 people viewed this question
Top Siemens Network Bridges Experts
john smith
Are you a Siemens Network Bridge Expert? Answer questions, earn points and help others
