Question about Philips 32PT6441/37 32" TV
TV shut down while watching
I was watching TV with my family one day when the TV decided to completely turn off. It's not an old TV and we didnt do anything wrong. We havent been able to get it back on since. When we turn the power button on, the green light flashes a few times and then shuts off. Can you tell me what I should do and if it's costly?
thanks.
  • cathynutt Nov 28, 2007
    I turned the channell and the t.v. just shut off. Now, It will not turn back on. It makes a click sound and the green light flashes and thats it. HELP me Please.
    Genius:
  • 1,694 Answers
Install horiz driver kit # 483513057673....applies to all L04.1
chassis.....+ replace 47mf/25v cap in horiz driver circuit...T.
Posted on Nov 28, 2007
SOURCE:
Colour keeps going green all across picture
Going "Green" with HDTV In addition to considering screen size, TV type, and available features also consider ways to conserve energy. Below are a few energy consumption tips for your HDTV:
Turn the TV off when not in use.
Turn on the power-saver mode
Many TVs these days come with a power-saver mode that's designed to cut down the power consumption. Performance of this mode varies from model to model, with the effect sometimes being drastic and other times providing only a slight savings. The only downside is that the power-saver mode usually makes the TV less bright, but we've found that sometimes this has a beneficial effect on the image quality, especially with the room lights turned off, in which case it's a win-win situation.
Turn down the LCD's backlight
Many LCDs give you the ability to control the intensity of the backlight in the TV. By turning down the backlight, you'll lower power consumption, but also make the television less bright. While retail stores love to turn the backlights up all the way for their displays, we find that we get the best image quality when we turn down the backlight significantly.
Control room lighting
Reduction in the intensity of the backlight is going to make the TV less bright, but that can be compensated by controlling the light in your home theater room. While this may be a little overboard just for power consumption, limiting the light in your home theater also goes a long way toward creating the "theater" experience, as well as getting the most out of your TV.
And beyond TV concerns, good-quality blackout shades offer thermal benefits that keep other energy costs low; they keep heat in during the winter and keep it out during the summer.
Watch TV together
Having multiple televisions in a house is more of a norm than a luxury these days, but that also means your power consumption is going to increase as well. You can cut that power consumption by watching with your family or housemates. You might need to make a few compromises on what you watch, but sometimes it's more fun to watch with friends and family.
Don't forget to properly recycle your old model
If donating or repurposing your old TV is not a viable option, CNET encourages households to recycle their electronics. Please explore the following websites to find a recycling center in your area Electronics Take Back Coalition or Earth 911.
HDTV source resolutions There are two main HD resolutions in use today by HD broadcasters and other sources: 1080i and 720p. One is not necessarily better than the other; 1080i has more lines and pixels, but 720p is a progressive-scan format that should deliver a smoother image that stays sharper during motion. Another format is also becoming better known: 1080p, which combines the superior resolution of 1080i with the progressive-scan smoothness of 720p. True 1080p content is extremely scarce, however, and none of the major networks have announced 1080p broadcasts. The term 1080p today appears mostly in reference to the displays' native resolution, not the source.
Jul 03, 2011 | Televison & Video
HLR 5067W 6yrs old. I replaced the lamp and color wheel about 3 years ago. Last week the TV would not turn on. Fans run hard, no light from the lamp. Tries for 3 cycles, then shuts down and front...
Tv is on every day and watches 4 to 5 hours every day?Yes,3 years now the projection lamp require replacement again and the board that call the Ballast board might require replacement too,this Ballast board only job is it to ignite the projection lamp only..
Jun 04, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
TV SCREEN WHILE WATCHING WILL BLINK AND BLANK INTO BLACK SCREEN
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
May 11, 2017 | Philips 42PF9631D 42 in. Plasma Television
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Power button lights up3 times then shuts down rca d52w20b
SORRY but only you can decide when enough is enough to waste repairing the dinosaur and move on to a more dependable unit .
Oct 08, 2017 | Akai PT5492S 54" Rear Projection...
Tv won't turn on
I hear they have weak power supplies
Sep 05, 2008 | Samsung TXN3271HF 32" TV
Brief power on then shuts off
It could be a component short or crack on the power supply board. Open the back of the TV and look for signs of defect. The power supply board is the brown one on the right with huge capacitors.
Jul 12, 2008 | Panasonic PT-61HX41 61" Rear Projection...
TV Dilemma
you have a stuck vhs tape in it.
Oct 20, 2007 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Philips 32PT6441/37 32" TV Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
