Question about SanDisk Sansa e250 MP3 Player
E250 Problem i have a sansa e250. When i turn it on the sandisk logo and the sansa/rhapsody logo just keeps looping over and over. it will not shut off with the power button, but with the hold switch. i tried the recovery mode but i don't think i have the program on my computer. i need some help before the hammer comes down on this MP3 player. Thanks
  • 626 Answers
You have the Rhapsody version, the fix is different.
Try the following:
Please copy and paste the following links into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your desktop.
http://rapidshare.com/files/67740209/rhapsody-1.0.2.21.zip
and
http://rapidshare.com/files/67740700/sansa.rar
1. Double click on My Computer so that you can see it on your screen.
2. Turn the player off.
3. On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see the orange colour.
4. On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under "My Computer" called "16MB FORMAT". Once you see that icon you may release the Record button.
5. Double click the RHAPSODY-1.0.1.47 file you downloaded earlier and open it. You will need WinZIP or WINRAR to "unpack" it. Inside you will see a file named PP5022.mi4 drag this file onto the 16MB Format in My Computer mentioned before.
6. Double Click on the Sansa.rar and open it. Drag the Sansa.fmt file into the 16MB Format as well (this forces the device format and erase all data)
6. Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
7. Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Please RATE my solution at the bottom.
Best of Luck.
Posted on Nov 28, 2007
SOURCE:
My sansa e250 is stuck in the beginning of the refresh screen
Download the Sansa Recovery Tool from Sandisk's website and try again. Is your Rhapsody subscription up-to-date. If not, update your subscription.
-Tha mp3 Doctor
Dec 25, 2008 | SanDisk Sansa e250 MP3 Player
No subcsriuption to rhapsody, can I still listen to the music
You have to renew if you want to keep the ones that are on there now. Better to delete them all, and get a free music svc like Limewire.
Dec 10, 2008 | SanDisk Sansa e250 MP3 Player
Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 firmware problem
Verify that the device DOES NOT say RHAPSODY on the back or E2**R. This would indicate the rhapsody version, whereas the firmware is totally different.
If it is simply a E200, try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 28, 2007 | SanDisk Sansa e250 MP3 Player
Downloded recovery from sandisk website now get error msg
That software only works with the non-Rhapsody versions, hence the error message. You can call technical support and they can walk you thru the fix. Its too much to type. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 10, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e250 sandisk and rhapsody logo flashes on and off
As I mentioned in your 'other' post. It is the wrong version of the software. Contact Technical Support to take care it. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sandisk sansa e250 only sandisk logo on powerup
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Again, select format when prompted. Best of Luck.
Sansa e250 keeps shutting down
try and see if it is in MY COMPUTER if it is there download the newest firmware and update it if that doesn't work uninstall the mp3 player from your computer and then installit again.
May 20, 2007 | SanDisk Sansa e250 MP3 Player
It wont turn all the way on.
I have this same EXACT problem. Call the support system and they may be able to replace it or send you an email. Although I never got the email.... Sorry, and hope this helps.
Apr 02, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
108 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
