Question about RCA HD52W56 52" Rear Projection HDTV
Cutting off at different intervals
At different times, nothing specific, the tv will act as if if it losing power. The screen will flicker up to 2 times, and then the tv will shut off. You can turn it back on, in about 45 sec-1min, and it will be fine. I have noticed that it happens most often while watching a dvd. Any solutions?
    President:
  • 4,402 Answers
It could be high voltage cap located by flyback,if you have back off of tv and turn tv on,you will see green led's turn on,(on the board)if they turn off there is a small blue high voltage cap hidden under glue(i believe it's a 102 cap)that would be the one change,99% of time that is what will fix problem
Posted on Dec 15, 2007
SOURCE:
When the washer is on the spin cycle, I seem to be having power flickering off. I don't see any obvious lose connections. What connection could I check?
Have you checked the main plug. is it a fixed plug or one that has been fitted by someone?? CHECK.
If flickering only at times then it seems to me the main board or timer could be lose? Are you positive you have checked every section? You sound confident in doing checks. Make sure not plugged in when your doing your checks. Be safe.
Check on a different mains socket also. If stops, then the wall socket may be faulty. DONT USE. Lose wire in socket?????
Jan 01, 2016 | Whirlpool duet Washing Machines
Wont power up screen flickers
Where do I begin? 4 years ago when I first had this problem I was able to fix it by replacing 2 capacitors following the instructions here.
http://www.fixya.com/support/t293971-37_polaroid_lcd_tv_turn
That worked for well 4 years, now I'm having the same problem again with what appears no fix in sight, 3 more capacitors have gone bad, been replaced and nothing. I'm working on it but losing hope, I'll definitely return here regardless of the outcome.
In the mean time anyone reading this DO NOT buy or even take for free a Polaroid tv, it's not worth the drama.
Oct 19, 2012 | Polaroid FLM-3734B 37 in. LCD HDTV
Playstation 3 Flickers when set to 1080P on 32LG70
This may help... open Display settings, scroll down to the Deep Color option... switch it from automatic to off. So far this is the only solution that I have found
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
1998 Bravada, losing power, now wont start
Does it have spark , fuel pressure ? If the starter spins the engine an does not start an run , you have a fuel delivery problem or a ignition system problem . There are videos on youtube showing how to test for these .
May 24, 2017 | 1998 Oldsmobile Bravada
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Losing picture color on TV
Screen flicker can also be a bad dynamic black unit. Do you hear a low pitch growl when it flickers?
Dec 30, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
26 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
