Question about One For All URC4220 Remote Control
WONT OPERATE MY INSIGNIA TV
I EVEN CONTACTED ONE FOR ALL..THE CODES THEY SENT WOULDNT WORK EITHER,,THE REMOTE SAYS ITS GARR. TO WORK ANY TV..I THINK SOMETHING SHOULD BE DONE ABOUT THEIR BUSINESS PRACTICES.,,BUT I NEED MY REMOTE TO OPERATE..ANY NEW IDEAS?
    Novelist:
  • 129 Answers
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4220
just right click and save as on the download links.
you can also try the search method which should be lsted in the manual, this will cycle all the codes and you may find that another code also operates your tv including all the functions.
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
SOURCE:
LOST BOOK WITH CODES FOR PHILIPS REMOTE FOR INSIGNIA TV WONT WORK
INSIGNIA TV Remote codes, use the below codes to control your Insignia TV with a universal remote.
0103
0189
0217
0135
0133
0116
0167
0456
0029
Best idea though is to buy a replacement remote for your television. check the link.
Replacement REMOTE FOR INSIGNIA TV Google Search
Feb 24, 2017 | Philips Televison & Video
My tv won't take commands from my remote, it will shut down, but not restart
If you are using a none original remote then not all remote codes will work all the functions. Some codes are designed for different models. So you might have to try several codes before all functions will work. Even then some might still be missing.
If you are using a new genuine remote and it's still playing up. Then either two possibilities can occur. The set has been switched to work a different remote. Or there's a fault in the set that has either effected the remote functions or has caused the functions to cease to operate, even though the remote is sending out the correct signal and the set has received it.
Sep 25, 2016 | Insignia Digital-to-Analog Converter for...
I need a code for a universal remote.
Check this code;
0456 [0029 0905]
Where the code is listed as [### ###] the first is for the TV and the second is for the DVD. Otherwise just the one code operates both the TV and the DVD.
Jun 17, 2012 | Philips Remote Control (484E11) Remote...
Hi, i was trying to turn down the volume on my insignia but i accidentally hit the channel button instead and it wouldnt let me go back so i think i messed up my tvs programming. how do i fix this?
The TV's Ok, your remote has a keyboard problem - a key is stuck or has gunk stuck under the
key's contact pad. Clean the remote's keyboard contacts with a pencil eraser (mildly abrasive) to
shine up the contact(s).
Mar 24, 2011 | Insignia LCDTV26 26 in. Television
Having trouble getting my Dish Universal remote to connect to my Insignia 19" flats screen television. I think it is the silver (ES3189) model remote
traceroberso,
I came across your post. Are you still having problems with your DISH Network remote operating your Insignia TV? If you still are, I have 2 codes you can try to see if it will work on your TV. The codes are: 720, 539. The steps to program the remote to the TV are below.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network - Executive Offices
Nov 11, 2010 | DISH Network EZ Remote Remote Control
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Mar 24, 2010 | Insignia NS-LTDVD19-09 LCD TV
Can't program my DirectTV remote to control my Insignia TV (no Insignia remote code on DirectTV's remote programming menu)
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
May 05, 2009 | Insignia IS-LCDTV32 32 in. Television
URC 4220 will not operate 14" Insignia TV (NS-14FTV)
need code to set my urc4220 universal control for my zenith tv
Mar 22, 2009 | One For All URC4220 Remote Control
Direct TV Remote Control RC64 Code for Insignia TV
http://www.fixya.com/support/t1555766-direct_tv_remote_control_rc64_code this worked for me after doing a GOOGLE search. 10150 is the code that even worked for TV power. Here are the other codes supplied, in case link didn't work, 10463, 10054.
Good Luck!
Jan 17, 2009 | Universal Remote Control DIRECTV Universal...
Remote code for Insignia DVD/VCR combo and Winbook 32LCD TV
I have a Onkyo HT-S70 surround sound amplifier with a remote control. I am trying to find out what the code is to operate the Insignia BlueRay DVD player from the remote control?.
Oct 05, 2007 | Zenith ZN-501S Remote Control
One For All URC4220 Remote Control Logo
Top One For All Televison & Video Experts
Steve Allison
Steve Allison
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
