Sounds like a similar problem. My brightness menu keeps popping up and going to 100. The brightness is brought up with the up arrow and volume by the down arrow so could be similar issues. I have diconnected all cables and let the monitor sit for several hours with no power or other cables attached, so resetting all connections had no effect.
This problem is usually caused due to a faulty microswitch in the brightness button. To rectify this, you'll have to change this switch.
Get your monitor serviced by a qualified service personnel.
Hope this solves your problem. For more help or clarifications, please reply. Thanks.
not able to get nbc network .have old tv working on same antenna with converter box and i can get it...
(More)
not able to get nbc network .have old tv working on same antenna with converter box and i can get it there,not on my hannspree
Setting up my new 28" Hannspree and having problem getting a signal. Try to setup to directv...
(More)
Setting up my new 28" Hannspree and having problem getting a signal. Try to setup to directv satellite box but not sure what I'm doing wrong. Please help??
I'm having the same problem but with my monitor showing the volume bar. It keeps wanting to turn...
(More)
I'm having the same problem but with my monitor showing the volume bar. It keeps wanting to turn the volume all the way down. I discovered this when I tried to turn the volume up, that it would quickly turn the volume down again. In addition, I was able to get it to the menu settings and noticed that it would cycle down through the options and repeat, starting back at the top.
