Think electrical 1st itz the weakest link-have you done a toonup-chec plug wires for wear or failure also distributer system up to 100,000 volts are used -these things fail from the heat 2nd test the fuel pump or pressure reg for gas inspect total ride for loose wires etc consider a scan 3rd
Firstly Demobilize your imubilizer,secondly check ignition fuse,your fuel pump and make a presure test,bad spark plug
SOURCE: the c280 just switched of whilst driving just cranks but does not
There is a problem with these models with the float in the gas tank. Check that you have over half the tank full of gas. If its under half and won't start then the float could be your problem. You can solve it by just keeping more than half the tank full of gas or by replacing the float which is expensive. Let me know if this helps.
