Question about Abbaka BAW-3620 Kitchen Hood
Halogen light covers need replacing model BQ025
Light covers on hood lights are broken and need replacing. where can i find the covers?
  • range hood Oct 24, 2008
    Same problem, actually its has not been the best of lights, one of the three, the cover over the light came off, and we haven't had a replacement on it. Now the other one is totally out. Where do i find replacement lights and covers
  • 833 Answers
Customer service for them: 800-548-3932
Posted on Dec 09, 2007
SOURCE:
COOKER ISLAND RANGE HOOD GL9002 4-12V. HALOGEN BULBS GO OUT THAN GO ON, NO OBVIOUS SIGNS
* Check your warranty. Call for service.
*** following is for information only.***
* Range hood lamps are usually available at hardware stores; Lowe's, Home Depot, or a lighting store. Take the old bulb to store for an exact replacement. There are many different bulbs though these are common for track lighting, etc.
* Note; not all range hoods us Halogen. You will find LED lights starting to show up on hoods. I'm not convinced they are the best choice (LED) for a heated area as LED is an electronic device that is sensitive to heat. Halogen's have another use (used under the hood). They do produce heat as with counter top heat lamps used at restaurants. Though not a lot of heat, you can still feel the warmth from Halogen lamps when turned on High settings.
* Golden Vantage (specs); https://www.amazon.com/ask/questions/asin/B00ASQJ7RS/2/ref=ask_dp_iaw_ql_hza?isAnswered=true#question-Tx2BW19EX2L2JVQ
Aloha, ukeboy57
Jul 12, 2018 | Kitchen Ranges
Instruction manual KuKoocooker hood light bulbs
Just look this youtube video, and it can't be more clear.
Don't forget to unplug the hood, or switch it of. Although the halogen lamps are only 12 volt. In the hood are dangerous voltages. How to replace cooker hood halogen bulb or lamp
Sep 22, 2014 | Kitchen Ranges
Replace halogen bulb
Please see my answer at http://www.fixya.com/support/t9977585-sv168n_36_spagna. I suspect your problem is with a failed transformer, rather than the actual halogen fixtures.
Oct 29, 2013 | Euro-Kitchen SPAGNA VETRO 198D-36...
Need replacement halogen lights for SU3
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Mar 07, 2013 | Sirius Hoods SU3
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do you fix a 2008 HYUNDAI SONATA front head light?
The halogen headlight is basically a bulb that is replaced from behind the headlight assembly inside the hood. Hyundai has a cover that keeps moisture and debris out. To remove it, simply twist the cover counter clockwise. Once removed, you should be a locking "bracket" that will resemble a small wire handle. This locks the bulb into place. The handle can be released by "squeezing" it together (on some models, the handle is kept in place by a notch) and pulling up. Once released, you will be able to remove the plug and old halogen bulb.
Once the bulb is replaced, reverse the instructions to re-assemble. Best of luck and thank you for using Fixya! Greg
Feb 17, 2011 | 2008 Hyundai Sonata
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
How do you replace the light bulbs? There is a lens cover over the bulb.
This is how to replace the lights on the KitchenAid khlu162m hood. If this is not you hood please give the right make and model # so I can get you the right info.
Replacing the Halogen
lamps:
The hood liner uses 12-volt, 20
watt halogen lamp bulbs.
Before you begin, make sure that
the range hood is turned off and
that the lamps have had sufficient
time to cool.
To replace a halogen lamp:
• Remove 2 screws from the
circular metal trim around the
lamp assembly.
• Pull the trim with the lamp
assembly attached down far
enough so that the lamp can be
pushed out of the socket clips.
• Insert the new lamp into the
socket clips and push the lamp
and trim assembly back up into
the hood.
• Replace the screws.
Good Luck and please rate 4 thumbs up for the free answer.
Jun 13, 2010 | KitchenAid KHLU162M Kitchen Hood
Glass Surface Light Lens Cracks from Halogen lights use
The lights do get very hot, so they must be a sufficient distance from the lens. Was there an instruction sheet with the new lens? You may need to adjust the sockets upward. You might call a local GE-authorized servicer to see. Concerning the vent fan, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 06, 2007 | GE XL1800 1100 Watts Microwave Oven
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Mar 28, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Abbaka BAW-3620 Kitchen Hood Logo
674 people viewed this question
Top Abbaka Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you an Abbaka Kitchen Range Expert? Answer questions, earn points and help others
