Question about Printers & Copiers
Okidata C5150N-040:FATAL ERROR
My Okidata C5150n kept jamming and we couldn't clear the jam. Couldn't find any paper to remove anywhere. I ended up turning it off and turning it back on at which point, we received a 040:Fatal Error Call Service. We can't get beyond that. Any suggestions?
  • 1113 Answers
SOURCE: Okidata C9500 DXN--Printing Issues
Your asking a bit much
1) - Power ON printer while holding both the + & - buttons until “OKIUSER” message appears in LCD.
2) - Press + or – button until “ENGINE DIAG MODE” is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or – button until “NV-RAM INITIAL” is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. .....
..........the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
Posted on Nov 19, 2007
  • 832 Answers
SOURCE: paper jam, open back cover, then remove paper jam
Ther is some tiny little paper piece left in the machine! You will find it at the left hand side near the gear wheels ;-)
Posted on Jun 15, 2008
  • 260 Answers
SOURCE: oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Posted on Apr 09, 2009
  • 5660 Answers
SOURCE: HP 1350 Says theres a paper jam and won't clear. All lights on.
Try unplugging the printer from power, (Turned off of course) Wait 5 minutes, plug the printer back in. Now open the case like you're going to clear a paper jam, or change ink cartridges. Close the case. Press the Power On button of the printer.
Posted on Jun 05, 2009
  • 9 Answers
SOURCE: Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
A 020 error is the TNY on the controller board. If you take the controller board out (it's the board that the usb/network cable plugs into). You find 2 banks. Ones for memory, the other bank is your prom board they refer to as a TNY.
Call Okidata, order a TNY for the C7300, probably bout $130.
Posted on Oct 31, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
0 characters
1 Points
I have am Oki Data C6100 and I just got a 980: FATAL ERROR message. I replaced the fuser about a month ago and now it is showing up again. Last Wed I had a paper jam several times. I took out the jammed...
paper jam is a main issue in printer when you clear the paper jam normally a tiny piece of paper falls into the printer and the printer get stuck again to clear the printer of tiny piece remove the toner and use a light blower and blow away the piece of paper this should be done only after removing the power and the usb from the printer after cleaning connect the power and the usb and restart your computer
Jun 28, 2011 | OKI C6100n Laser Printer
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
Feb 14, 2010 | OKI C5500n Printer
How do I reset paper jam on my okidata 7300 when there is no paper present I inspected top bottom and front no torn pieces visable, including duplexer Hamilton
The jam indicator clears when the jam is removed. If you don't see a jam but it still indicates one the a sensor is dirty, popped out, or bad.
Jan 03, 2010 | OKI C3400n Laser Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Code 200.13
Replace Sensor Input Media and it should fine The part Number 40X1223 the cost around $3.60.
Apr 24, 2008 | Lexmark X342n All-In-One Laser Printer
Fatal Error
unplug and plug back in.
Jan 15, 2008 | OKI C5150n Led Printer
Paper Jam Error 2
Don't try a dozen things suggested by people online who's credentials are unknown. Go straight to the source.
I had the same issue and just went to - looked up my model #, downloaded the PDF manual 86 pages and did a search for that error. It had step by step picture diagram of how to clear out the jam.
I just saved the company a few hundred on a service call to our printer sales/service vender.
Oct 28, 2007 | Samsung SCX-4100 All-In-One Laser Printer
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
Printers & Copiers Logo
164 people viewed this question
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
