Question about Nintendo DS Console
Ds light not coming on and charger not working
One day i was playing my ds, but the next day, i charged it for like 6 hours but it still wouldnt come on
  • 12 more comments
  • Anonymous Dec 03, 2007
    well i have a ds and when i plug the ac an orange light blink on the ds and thats it i'm unable to charge it ..
  • Brent24 Jan 02, 2008
    I have the same problem with my DS. I plug in the charger the orange light flickers on then either immediately turns off or turns off within a couple seconds. Ths problem occured out of the blue, I played it the day before and it was working fine. The next day I was unable to turn it on and have not been able since, which ahs been a couple weeks. If anyone else has had a problem similar to myself and had it fixed please post a response on how to fix the problem without paying $75 to Nintendo, I would rather buy a new system for that much.
  • Anonymous Apr 18, 2008
    Same - I have a Crimson & Black DS Lite and I only just got it today. The battery was low so I tried charging it but the charging orange light flickered for less than a second and it wouldn't charge...
  • Brandon Burnett Jun 09, 2008
    with ya. except this happened with my nyko charger grip lite
  • CHRIS CARRILLO
    CHRIS CARRILLO Jul 01, 2008
    I had the same thing.I came from school and a orange light was on.I charged it a lot nothing.it was still there when i tpushed it up and down it was still there.Later i blew the openings and I turned it on and was red.Do i have chance that it will still work after charging it?
  • Anonymous Jul 05, 2008
    When I hooked up my DS with the charger the orange light would flicker then turn off. The DS wouldn't charge.
    What I found that worked was KEEP THE DS ON AND OPEN while hooked up/charging. Although this does help, the charging goes extremely slow because of the DS being on.
    The best thing to do is to return/exchange it. I just did that today.
  • Anonymous Nov 17, 2008
    My ds was hooked up to the charger and the light went on and then is turned really fast off.
  • Anonymous Jan 25, 2009
    it just not working and when I shake it I here somthing in it.
  • Anonymous Mar 25, 2009
    i hooked up my charger but it only charges for 1 second and my ds wont com on
  • nedfan_1 Apr 03, 2009
    light only comes on for a second when the cord is plugged in, DS will not come on
  • blade9 Apr 03, 2009
    when i plug in my ds the lite to show it is charging is not coming on so i turn it on and it is still dead what should i do i want to play back my ds msn email me at msn blade9@live.com
  • Sarafiena378 May 17, 2009
    when I hook up the DS to the charger it won't charge
  • TJTay May 20, 2009
    when i shake the charger, something is inside. Is a part loose? Help!
  • Anonymous May 26, 2009
    i found this ds and its not working, when i shake it somethings inside butit still not working. even charged it still not work.PLEASE TRY SOMETHING TO HELP ME FIX IT ! CAN YOU PLEASE BUY ME A
    NEW ONE PLEASE
When I hooked up my DS with the charger the orange light would flicker for only a few seconds then turn off.
I found out that if you KEEP THE DS ON WHILE HOOKED UP the DS will charge. Although, because you are playing/DS is on the charging will go extremely slowly.
Best option, and what I did, was was just return/exchange it. I just did that today.
Posted on Jul 05, 2008
  • Akosua Frimpong Nov 07, 2011
    a i I have the same problem, its a red DS Lite, I put the charger in, I got orange light for about 1 sec and it disappear and I cant charge or power up my DS.
    Problem Solver:
  • 9 Answers
Okay guys and girls, lots of posts on this but let me share my views on this.
If you have a bad battery there is a chance you are going to get that light popping off after a few seconds or just staying amber forever. you can easily check this by trying a friends battery in your unit right? or vise versa, try your battery in another unit.
If the battery is not bad then you have another problem...
If your light is flickering on and then off again you may have blown a fuse. The DS has two fuses, this is a common problem. Google it theres info out there on this.
If your battery is charging up and the light is staying on this is sometimes not a problem to be honest, it could just mean your battery is fully charged. The problem with your DS not powering up could be as simply as a faulty switch. To determine this I would first make sure that your DS is charging up batteries fine, maybe try a friends low battery. if you have a faulty switch this is nothing major to replace but you need to be half decent with fixing stuff dudes to crack open that DS and start playing.
Good luck all.
Posted on Jun 17, 2008
I ahd a old ds and that happend but with mine i could shake it and i could hear the battery witch had broken in half i dont know if this applys to you but just some advice!
Posted on Dec 21, 2007
My DS also just stopped working. The battery just stays orange forever while charging and it won't turn on at all. We replaced the battery with a new fully charged one and it still will not come on. It doesn't have any rattle to it, and has been cared for. Also, it's not the spring in the power switch. It is out of warranty and Nintendo will not help. I'm out of options. Any help? Email me trombonedude13@yahoo.com
Posted on Jul 24, 2009
    Sergeant:
    Champion:
  • 250 Answers
It's time for a new battery for those with the flickering light and no charge. Also when the battery is bad the DS will not run on the charger. You can get an official DS battery from Nintendo for $15 on nintendo.com or you can get a cheaper knock off on ebay for under $10.
Posted on Mar 06, 2008
Problem with powering up ds nutiendo
Posted on Mar 04, 2008
Guys there are 5 things why his happen to chargers 1 the wire is removed because of bending
2 charging the nds while some cool epic game
3 battery messed up because too much charging (like all night charging) should have been only 15mins
4 the nds charger screws are almost remove this make the chargers battery conductor shakes
and 5 for the ultimate problem
5 too much pressure of the player so angry he will throw his charger and then it break
no.5 happen to me Lol xD hahahaha imma buy new charger and throw my old one mine is crimson red with wood R4 T_T hahaha i'm not been playing since 50 mins mine broke just later so see yah ghuys hope this atupid solution did'nt help you
Posted on Nov 14, 2011
I have a difrent problem but almost the same i got a blue d.s light and the charger wont work unless the d.s is open and on but i cant turn it on cus it needs to charge and i need to know how to fix the charger or the d.s
Posted on Feb 28, 2008
  • 1 more comment
  • pedro martinez
    pedro martinez Feb 28, 2008
    i have almost the same problem my ds wont charge unless it on and open but i cant turn it on becaus it needs to charge and i need to know how to fix it
  • pedro martinez
  • chelseyalcar
    chelseyalcar Jan 28, 2013
    i have a problem to my ds nintendo the charger is not working
  • 4 Answers
If the light does not come on it means it is fully charged
Posted on Feb 25, 2011
    Problem Solver:
  • 12 Answers
Open your charger and see if there is anything loose. my chargers cable was disconnected so my ds charging light would stay on for a few secs until the wire was pushed away. so just check and solder if needed.
Posted on Jun 08, 2010
I have a ploberm.when i charge my DS, the orange light come only a blink.how can i fix it. Please tell me.
Posted on Jun 19, 2008
It happend to me too but turns off in like 1 minute
i think eb games of game traders will sell some new chargers XD
Posted on Mar 02, 2008
When I charge my DS Lite the orange light is on all the time but i still can't play it! Can someone help PLEASE
Posted on Jan 21, 2008
The Guest who posted reply on Dec. 3, 07, I have the same problem, its white DS Lite, I put the charger in, I got orange light for about 1 sec and it disappear and I cant charge or power up my DS.
Posted on Dec 30, 2007
The same problem of everyone's DS is happening to me too! I'm doing a variety of different things to Test... I am having this problem with my DSi as well, So I'm looking into Solutions of problems! Hope to get the Answer soon! For now, keep gaming... On a working console, heh heh...
P.S. I just signed up and wanted to write a little note to the owner(s) of this website. It said "You could even earn a little cash!"... I do not want this as for I am to young to give any kind of that information out! But I'm a whiz with technology! Have fun gamers!
Posted on Jan 27, 2011
That happend to mine to. My black ds lights dose the same thing plz help.
Posted on Jan 27, 2008
  • ninjapup Jan 27, 2008
    My black ds light did the same thing plz help. i think its a defect in the ds light.
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
I have a Nintendo DS Lite that will not charge. The orange LED does not come on at all and after leaving connected for 12 hours, the battery is not charged, red LED comes on after a second or two. I have...
it sounds like it's a battery problem.
If you want to replace your battery, call Nintendo's Consumer Assistance Hotline at 1-800-255-3700 from 6 a.m. to 7 a.m. Pacific Time, and order a replacement battery there. I believe it costs around US$15.00.
If you still need assistance I would suggest you check our online troubleshooting here. Depending on the specifics of your situation, the problem may be the DS Lite, the battery, or the AC adapter.
PCHELPSTER007 from youtube
p.s. Before doing this you could maybe try using a different charger
Aug 29, 2011 | Nintendo DS Lite Console
When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
I hope this helps you. -
Frankie.
May 11, 2011 | Nintendo DS Lite Console
I got my DS in 2009 april, then on september i lost my charger then on march 2010 i found my charger then i found out i could'nt find my DS anymore a few months later i found my DS i charged then it...
The red LED indicates low power. When the DS is charging an orange LED should be on and the DS can be switched on, giving a second green light. If you tried charging it but the orange LED did not come on or only came on for a few seconds then the battery has not charged. The charger may be faulty or the power connector on the DS may be faulty. You need to try another charger. If another charger does not work then the DS is faulty and needs repair. It could be the power connector or the battery or some other fault inside.
If the amber LED comes on to indicate that the battery is charging then the battery should be fully charged within 3 hours. If the DS does not switch on after charging then the battery may be faulty. It can be removed by opening the cover on the bottom of the DS.
You should try and find a friend with a DS who will let you try their charger and battery in your DS.
If the DS itself is faulty it will probably be uneconomical to repair. If this is the case then try selling it on ebay as a faulty DS.
Oct 30, 2010 | Nintendo DS Lite Console
Ds doesnt charge or turn on
The NDS enters the sleep mode abruptly
1.It is possible that external magnetism causes the system to enter in sleep mode .Therefore ,keep the system away from nearby magnetic objects
Jul 20, 2009 | Nintendo DS Lite Console
DS is stuck in charge mode when plugged in.
Your DS may have a problem reading the battery gauge, and the DS will only let the charger do its thing for a period of time. Then, if it is still connected, it may burst more charge in. This means that your DS is acting up, and your battery may have a rare (and not harmful to the DS) malfunction.
Jun 10, 2009 | Nintendo DS Console
My DS will only play when plugged in
You have a loose fuse on your circuit board, or your charger port needs to be replaced.
I will fix it for you. $30 for the work and I will pay the return shipping,
Thanks,
ninja_freak318@hotmail.com
Jan 05, 2009 | Nintendo DS Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Nintendo ds
There are a couple of fuses inside the ds and one of them is right up next to where the charger plugs in try to replace it. It is a little flat black piece with solder on each end and it should have a number on it you with need to replace it with the same number fuse.
Oct 03, 2007 | Nintendo DS Console
Nintendo DS Console Logo
7,985 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
