Question about Kenmore 63942 Dryer
Not Working When I close the door and turn on our kenmore 80 series dryer it does not come on
  • adallas Oct 16, 2008
    Dryer acts like its not getting electricity, so we stuck a tester in the 220V outlet. Not easy to do, but that proves the problem is with the dryer. Door switch could suddenly break, I guess, but it's not jammed or anything. We have a houseful of "amateur" launderers who, like all teenagers, slam things around. I'm assuming that the switch is connected to the latch--that there are wires in the door--since I don't see any other switch.
Got it. It was the door switch. I wrote that it "could suddenly break, I guess" and that's just what happened. The switch is not in the latch; there are no wires in the door. The switch is mounted on the upper right of the door frame. There's a black plastic paddle that closing the door pushes back. Ours broke off (making it harder to see). I'll order a new part, but for now, I taped a piece of plastic to the door that reaches the broken switch.
By the way, if you are new to dryer repair, as I am, you might not know that the top deck is hinged at the back. You have to pry up the front (there are two rubber restraints) after disconnecting the lint trap shaft. The door switch is easily accessible from the top (at the right). Don't forget to turn off the power.
Posted on Oct 16, 2008
  • 249 Answers
Door switch or fuse.eire bye
Posted on Dec 04, 2007
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
Kenmore Series 80 dryer, working open the door to check load, close door, and now it won't start. Any ideas??
The door switch broke...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 19, 2010 | Kenmore 63942 Dryer
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
Dryer won't start
Try 2 things to see what has happened.
1st listen for a click from the door switch just as the door opens or closes. (No click = no start)
2nd reach in and rotate the drum by hand just a little bit making sure you hear the motor also turn. Then try to restart the dryer.
If rotating the drum enabled you to start the dryer the motor switch is sticking.
Feb 25, 2010 | Dryers
I have electric series 80 kenmore, all of a sudden it wont turn on, still getting power because light is on when door is closed. turns off when door opened. hit button and nothing happens at all.
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Dec 13, 2009 | Kenmore 63942 Dryer
Kenmore 80 Series Electric Clothes Dryer-Won't Start
check the door switch , a little arm that clicks in when the door is closed. check to see if it clicks or if its even still there.
Apr 14, 2009 | Kenmore 63942 Dryer
80 series dryer Doesn't start but when you open the front door, the light comes on and when you close the door you can ear a click by the timer. Also, you ear the timer working
Replace the thermal fuse located on the rear of the dryer.
Remove the rear panel. The fuse is about 1 and 1/2 inches long and 1/2 inch wide and white in color.
It is near the exhaust vent.
Mar 21, 2009 | Kenmore Dryers
Kenmore 80 series Dryer: Door Light stays on and wont start
Mar 05, 2009 | Kenmore 800 7982 Dryer
Kenmore 80 series dryer won't start
Look for a bad thermal fus0526080941.jpge pix below.Straight wire to test it.Replace if the dryer turns on. 2nd. Test the door switch.
Please rate This !
Jul 09, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
151 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
