Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
My TV was fine this morning. I turned it off before going to work. Came back and turned it on.. all i see is vertical lines with perfect sound. Its two year old TV. Any help would be appreciated..
  • Anonymous Nov 30, 2007
  • kerleyman Nov 30, 2007
    Same problem here!
    Novelist:
  • 148 Answers
Pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Posted on Dec 28, 2007
SOURCE:
Good picture, no sound
hello, if you have a good picture then your set is serviceble make sure you check all your options and audio set up settings before you go futher, with this symptom your set displaying fine and sound not coming trough it could be a fualty sound board module this board is identified by aquiring a service manual and then using the schematic drawings location the board that controls sound, i would then find this board online at auction or parts site and have it exchanged. hope this helps
Jun 04, 2010 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
My 42 inch plazma turns on but ther is no picture
my ESA 42" plasma tv turns on no picture and no sound.
Jan 30, 2010 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
My fan is not working picture fades out when over esa plasma tv
need to bring to your tv service center before it blows out and becames more expensive to fix only a tv tech will be able to fix it,,
Dec 16, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Sep 24, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Wide vertical bands of color through the viewing area. The sound is fine
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
May 24, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Mar 23, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
ESA 42 in, has sound, screen has colored lines going thru.
what type of t.v is it.
Let me know, and i can help but to me it sounds like a busted Processor, but dont listen to me untill i know what your viewing candy is
LCD, PLASMA, OLED, DLP, LP, CRT what type of t.v do you have?
Mar 08, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Black lines on sony plasma tv
go here, it will work.  follow closely and read entirely!  it worked for me on a gateway plasma!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Oct 27, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
ESA 42" plasma tv not turning on
I have a 42 inch plasma and I was watching tv last night on it and suddenly it turned off on it's own. I tried turning it off and on and nothing happened. Then I tried to unplug it and replug it and nothing. My remote does not work either. Anyone know what exactly happened? Did my screen blow or what? I hardly ever use the tv and I only had it on from 8:30 p.m. - 10:20 p.m. and it turned off. All the other tv's in my house worked fine - I checked them. Also, my dvd player and cable box is on the same power cord and both of them work. Any solutions or help would be most appreciated!!! Does it just need to cool down or did I burn something out? Help!!!
Mar 16, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
333 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
